Results 1 to 10 of 10
Thread: replacing factory radio/ cd player
    Oct 2011
    melbourne
    gday all. am replacing the factory double din head unit with a single din uhf and stereo. has anyone done this before (sure someone has). do you have photos. mate of mine who is a sparky and pretty handy with this kinda stuff said he can do it for me. just wondering though, does a bracket need to be made or fitted to stop the units moving around. my mate assumes yes but not his type of specialty doing that. anyone who has done this and has photos or ideas is appreciated.
    cheers
    breno
    I assume a GU is a GU and all the same? On my GUV...
    If it's a genuine single din size aftermarket it should bolt up straight to the hardware that held the double din factory unit. At worst you may need to drill a couple of holes.
    The factory bracket is a hollow square held into the dash by 4 screws thru flanges on the front... the only challenge may be an appropriate surround or fascia
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    Have a look in my build thread and there are pics there frim memory from when I did mine
    Facsia is the same, you will need a pocket insert, after market aerpro plug and play wiring harness and an aerial adapter to change from oem to generic and all done, takes half hour or so the change
    Tap, Tap Taparoo
    www.swat4x4.com
    X 2 with above you should just need the single din dash pocket, CAUTION there are 2 styles
  5. #5
    Aug 2010
    adelaide
    doesnt need the pocket as he is putting in a uhf radio and a sterio and used the original bracket and wiring harnes from auto barn $15.00
    this is what i did in my gu and below is with the flip out screen
    OH LEATHER IS NICE
  6. The Following User Says Thank You to my third 256 For This Useful Post:
    beexy (23rd December 2012)
    Oct 2011
    melbourne
    256 thats exactly what im looking at doing. have got the plug and play from autobarn. did you make up a bracket to surround it or does it sit pretty snuggly as it is
    Yea, Victoria
    When you do yours can you put a pic up of how to get the facia off....??
    Patrol God wildgu6's Avatar
    Sep 2010
    Adelaide S.A
    If your talkin bout the face plate on the double din there CC, along the bottom of the faceplate you will feel 2 slots, use a screwdriver it the slots to pop it out, to easy mate
    TAP TAP TAP MERRY XMAS TO ALL AND A SAFE NEW YEAR TO COME
  10. #9
    Aug 2010
    adelaide
    Quote Originally Posted by beexy View Post
    goes straight in and is a snug fit no bracket was made used old one
    OH LEATHER IS NICE
  11. #10
    As mentioned above, when doing a double instal it should fit straight in.
    But for future if needed you can buy double din frames from auto barn, repco etc.
    Owner of
    Westy's Accessories
