Page 4 of 12 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 114
Thread: Solar charging
  1. #31
    178 Post(s)
    Another possibility which can make a panel appear to be putting out less amps than it is rated for is cable sizing. If too thin you get voltage drop (from the wire's resistance) & consequently less amps. A common trap for the unwary is that automotive cables sizes include the insulation so that, if for example someone needs 6mm2 cable for a certain length & buys 6mm autocable, the size of the copper core in the autocable will only be about 4.5mm2, & could easily account for the loss of a couple of amps output (lost to the cable as heat).I have used 6 B&S (13.2mm2) for a 10metre length to my 300w of portable panels.
    Last edited by Cuppa; 27th November 2012 at 09:39 PM. Reason: Corrected the size of cable I used for my portable panels.
  2. #32
    Patrol Freak lorrieandjas's Avatar
    Brisbane
    On top of that poor connections, regulators in the wrong position, etc cause losses - and in some cases significant losses. When you're talking 6 amp input and loss of say 1.5 amps then you're already 25% behind the game. Whilst there is science behind it all I think there is also quite an art in having a good setup that suits your needs. On the other hand - sometimes the effort to gain a little isn't always worth it! Depends on circumstances again!
    Jas
  3. #33
    My next question was. What about voltage drop through cabling? But its been mentioned. Cuppa, thats another thing i know I have to change on my panels. Do you have and recommendations of where and what to buy? Plus is using aligator clips still o.k to use?
  4. #34
    Thomastown, Melbourne
    6 Post(s)
    You lot hurt my head... Mark give me the lowdown when you have figured it all out!!!!!
  5. #35
    Yeah it does my head in too. I'm trying my hardest to understand it all.
  6. #36
    178 Post(s)
    This link should assist Mudski. http://hobohome.com/news/?p=581 The link has been around for a few years but the needed info still holds true.
    You will see that the cable sizing depends upon length & the wattage of the panels. For your 190w & say 10 metres of cable you will need at least 9.5mm2 of copper. This equates to to 6 B&S (or 6 AWG) as the next size up that is readily available. 8 B&S (thinner than 6 B&S) would be ok if you keep your cable run to 8 metres. (Probably what I'd do in your situation)
    http://www.engineeringtoolbox.com/aw...uge-d_731.html
    You will be surprised how heavy the cable is, but remember it's sizing is about reducing voltage drop, not about it's current carrying capacity. Aim for no more than a 0.3v difference between the output measured at the panel & at the end of the cable.
    For the sake of a just a few dollars fitting a 50amp Anderson plug to the end of your cable & to your vehicle (going to battery & regulator) you will get a much better & more secure connection than using alligator clips. Whilst you're at it fit the same at the other end of the cable & to the back of your panel.
    Mount the regulator as close to the battery as possible & if you can afford it, get one that has temperature compensation, preferably via a probe that goes to the battery. Even more important if the battery is somewhere subject to extremes, like under the bonnet, & the regulator elsewhere.
    Not sure I'd want to put a regulator under the bonnet, so would need to include the distance of cable between battery & regulator in the total distnce of cabling from the panels when working out cabling size. If you just went with 6 B&S it may be a bit of overkill, but you'd be sure you had things covered.
    Because of where I live I buy most of my stuff online. Ebay is my friend. eg. http://www.ebay.com.au/itm/10-METRES...ht_1223wt_1342
    Haven't used them but Jay-Dee in Bayswater have all you need & a downloadable catalogue. http://jaydeeautocables.com.au
    I bought genuine Anderson plugs after hearing stories of premature corrosion on the connectors of copies (Genuine have a silver coating). Corrosion will give head scratching problems if it becomes a problem.
    http://www.ebay.com.au/itm/ws/eBayIS...ht_4649wt_1108 2 pieces per connection.
    Cuppa
  7. The Following User Says Thank You to Cuppa For This Useful Post:
    mudski (27th November 2012)
  8. #37
    Cuppa your a champ. Your going to regret answering my questions as you know more will come. Actually, this was the reg I saw on Ebay to get : http://www.ebay.com.au/itm/370555699...84.m1423.l2649 I was just going to remove the crappy one off the back of the panels and put this one in its place. So I should really mount the reg actually in the car? What if I wanted to use the panels on a totally independent battery? Had plans on putting a third battery in a box in the trailer so the fridge or light could run off that too if needed.
  9. #38
    178 Post(s)
    You've heard the old saying 'Oils an't oils'.
    Well MPPT aint MPPT. The effectiveness of MPPT depends very much on the charging algorithms used & different manufacturers have different ideas about this. There is a reason why Blue Sky regulators cos 10 times what that Wellsee one costs, & even the Blue Sky ones aren't perfect.
    My view is that buying a cheap MPPT regulator is that it's not a great idea, & that you would be better off buying one without MPPT, just with PWM instead (Pulse Width Modulation). Now we are gettin to terms that start to challenge my understanding so I wont try to explain these terms.
    Suffice it to say I've heard others who know more than me advising to avoid the Wellsee units, & have read of folks that have been disappointed with them.
    For the kind of money you are talking about spending the following two regulators are ones that I know of. One that I've used, & one that a number of people I know have used, both succesfully over a number of years.
    http://www.ebay.com.au/itm/Solar-Con...ht_5736wt_1342
    http://www.ebay.com.au/itm/SOLAR-REG...ht_3425wt_1342
    Both have readouts which are useful in giving you an idea of whats going on.
    Yes mount the regulator as close to the battery as possible. A mate of mine (with the 2nd of those two regulators) used his panels to alternately charge batteries in his bus & in his trailer. His solution was to have the regulator attached to the end of the cable to the panels, inside a box with a perspex window, which lay on the ground, with a short cable going from it to anderson plugs on either the bus or the trailer (& then directly to the battery). The alternative is to use 2 regulators , one for each location. I have the Steca version of the first regulator. It has always falsely under read battery voltage by 0.3v but has been reliable & consistent & has temperature compensation, albeit not directly at the battery. The first one has a battery temperature probe & talks of protection against battery overheating but doesn't say it has temperature compensated charging.
    Cuppa
  10. The Following User Says Thank You to Cuppa For This Useful Post:
    mudski (28th November 2012)
  11. #39
    How much of a difference, really, is it going to be having the reg mount on the panels rather than closest to the battery? Never mind that question. Probably a lot considering we are only talking about 190W so every little bit would count hey.
  12. #40
    178 Post(s)
    Egg zactly.
