Results 1 to 10 of 10
Thread: New Tyre Sizing
    Advanced Muzza's Avatar
    Jul 2010
    New Tyre Sizing
    Well It's not new but for me It's new and I'll be honest, I'm confused.
    We used to always state our tyre sizes as 33" x 10 1/2" x 15"
    Now I'm seeing 285/65/r16 (assuming r16 = Rim size 16") (285mm is tyre width???) Whats the 65 for???
    So we are now mixing imperial with metric are we?
    Sorry for the basic question for most of you but for an old bloke It's confusing as hell. haha
    Thanks for your replies, just curious?
    Muzza
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Size Coding - this might help
    A tyre is referenced as "185/60R/15H", here is an explanation.
    185=A, 60=B, 15=C
    A = Width of Tyre (mm)
    In this example it shows that the tyre is 185mm wide.
    B = Profile as a % of width.
    (i.e. profile is 60% of width)
    In this example the ratio is 60%. This works out as 111mm.
    C = Diameter of inner rim.
    In this example it shows that the rim is 15" in diameter.
    From this you can also work out your rolling circumference.
    e.g. (2 x B) + C = diameter = d
    therefore (2 x 111 = 222) + (15" x 25.4 = 381) = 603mm
    circumference = pi x d = 3.142 x 603 = 1895mm
    ________________________
    ______ 2017 D-Max _______
  3. The Following 3 Users Say Thank You to Maxhead For This Useful Post:
    Finly Owner (11th September 2010), my third 256 (17th December 2010), nedoleboy (1st February 2011)
    65 (or the number that appears between the tread width and the rim diameter) refers to the side wall height as a percentage of the tread width. So using your example, the side wall height would be 65 percent of 285mm, what ever that works out to be.
    Tony
    Edit; beaten by 1 minute!
    ACT
    And yes, some smartarse thought it would be good to mix metric and imperial. I think just to confuse everyone.
    Or maybe the tyre manufactures have moved on in time and rim makers are still stuck in the dark ages. GO FIGURE
    Jul 2010
    I know, thats just confusing.
    mixing inches/mm as well as needing to calculate the percentage of width to work out your profile is just mad.
    Is there any logic behind all this?
    Cheers.
    ACT
    Not wrong about confusing.
    Used to be easy. 33x12.5x16 where 33 is your diameter, 12.5 is width and 16 is rim
    Now you have to calculate percentages, add, subtract and work out square root of pie to the power of 6 just to get the diameter.
    Expert Mark's Avatar
    Don't worry Muzza, I'm with you and to this day I still talk old school,
    Old dog new tricks kind...lol
    Jul 2010
    Waterford West Qld
    Quote Originally Posted by NissPat View Post
    185=A, 60=B, 15=C
    another one for the index file
  10. #9
    Expert ripper's Avatar
    Leeton NSW
    Just found a useful write up on Tyre sizes, Load ratings, Speed ratings, and more.
    http://www.carbonblack.com.au/car-ty...formation.aspx
    This could help too.
    http://www.1010tires.com/tiresizecalculator.asp
    1989 GQ LWB Wagon, TB42 Petrol/LPG Auto. Bought Dec 2010
  11. #10
    Here guys, here is a very good resource for instant conversions.
    Plug in what you want and it will tell you what to order or the equivalent is
    http://www.dakota-truck.net/TIRECALC/tirecalc.html
