Results 1 to 10 of 15
Thread: GU Rear Lights Mod
    Nov 2010
    GU Rear Lights Mod
    2008 GU walkabout 3L auto wagon, 2" lift, Nissan winch bullbar, Ironman winch, Roo lite spotties, Scrub bars & side steps,Ferret rear light bracket with two Led work lights.My tip, Always carry a good well stocked in date firstaid kit when 4wding medical help is always to far away.
  2. The Following User Says Thank You to bushytas For This Useful Post:
    MudRunnerTD (22nd October 2013)
    Nov 2010
    OK here’s the easy way to wire in your lights
    You will need
    5 meters of 5 core trailer wire
    2 plugs 5 or 6 pin I used computer power plugs from inside the case OME would be better but no one stocked them here
    A soldering iron
    A 10mm socket and ratchet
    Philips head screwdriver
    Flat screwdriver
    A knife or wire strippers.
    You will be wiring them to the trailer plug it’s the easiest way I know of
    NOTE: For reverse lights you will need to use the wire from the reverse light on the left hand side and run the wire across to the driver’s side
    5 Core Trailer wire
    First step is to remove on either side of the 4wd two 10mm bolts that hold in the lights
    After you remove the lights and soldered your plugs on run the wires.
    As you will see there is a grommet on either side as shown
    This isn’t a neat job but it works
    Wire to trailer plug
    Wiring for 7 and 12 pin plugs use the colour coding to help with lights
    Let me know if you need anymore help or would like me to explain a little bit more with any of this
    Brendon
  4. The Following 5 Users Say Thank You to bushytas For This Useful Post:
    beaST_01-dell (17th May 2013), CUROUND (6th September 2012), MudRunnerTD (22nd October 2013), ova50 (5th November 2012), the godfather (7th September 2012)
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Hi mate, have copied you posts to the new Electrical DIY section.
    Thought your work deserved its own thread
    Original posts can be found here still: http://www.nissanpatrol.com.au/forum...ht-on-GU/page4
    Todd
    Thomastown, Melbourne
    6 Post(s)
    Now come and do mine!!!!!!!!!!!!!
    Advanced CUROUND's Avatar
    Alice Springs
    Cool I like this very much, had been checking out the mod's with some one elses GQ and would looooove to do it for my GU or is it DX???
    Thanks Bushtas..
    Just a thought have you this information on a pdf file. Would very much like to print it out so I can use it to have a go myself...
    Half deaf, half left and halfway across Aussie!!!!!!
    Alice Springs
    OH, forgot to ask, where did you get the aftermarket light's from???
    Cheers..
    Quote Originally Posted by CUROUND View Post
    Cheers..
    Plenty of after market lights can be found on eBay........ And if you wAnt a print off, sa.ve the piccies to your pc, open up a word document and then you can copy and paste the text into that and insert the pics from your pc. You've the got your own copy to print off........ There's probably a better and easier way but maybe one of the computer gurus can help there
  10. #8
    Beginner Adventurous's Avatar
    Oct 2013
    Land of the Unexpected (PNG)
    Just out of interest, what is it about Australian Regulations that has many 4WDs not utilise the 'normal' rear lights?
  11. #9
    Quote Originally Posted by Adventurous View Post
    Because the spare tyre is mounted on the door it is considered an obstruction! Go Figure???? you'd think that they would just Add the extra lights to the lower Bumper area and keep the better lights in the side guards as they are clearer and far more visible 99% of the time. Just Dumb!
    GQs were the same. but all manufactures have had to do this. Nissan Toyota, Mitsubishi, Holden etc, etc. Silly Law
  12. #10
    Oct 2013
    I agree - add more lights!
    So I guess the manufacturers removed the higher lights for cost reasons, but it is legal to use them (as long as it is in addition to the lower lights)?
