Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Tigerz11 Winch
    Expert Tonks's Avatar
    ACT
    Tigerz11 Winch
    G'Day everyone, has anyone installed a Tigerz11 winch into a Factory GU111 steel bar, if so did you have to rotate the gear box to be able to access the gear lever and also did you mount the control box on top of the bar or did you knock out the section provided in the bar itself,
    Cheers Tonks.
    Expert Gas_Guzzler4800's Avatar
    Aug 2011
    Capalaba
    Yep I had to rotate the gearbox, very easy to do. I popped out the section and made up two L-Shape brackets so the control box sits just below the top of the bullbar. I have plans to refit the section of bullbar with a cutout for the hand controller plug, but havent gotten around to it as yet
    Nov 2011
    Brisvegas Northside
    Sweet just about to do this myself in next few days. Thanks for the picture....how's it working?
    Any dramas?
    Dave
    99 GU 2.8 TD
    Brisvegas, QLD
    Aug 2011
    Capalaba
    Havent had a real chance to use it in an actual recovery, but just playing around with it it seems to pull very strongly, pretty noisy compared to other winches but who cares. I had to pull the bullbar off as it just would not fit up there, it made it far easier to sort out the bracketry for the control box anyway.
  5. The Following User Says Thank You to Gas_Guzzler4800 For This Useful Post:
    Tonks (11th July 2012)
    Expert Rip'n'Shred's Avatar
    Hunter Valley, NSW
    Mine is a GUIV.
    I rotated the gearbox on mine, though I did have the winch fitted to my previous vehicle which I did also rotate the gearbox, so it may or may not be back to original position.
    I mounted the control box in the same spot although the cut out in mine is more triangular. Just made up some brackets and turned the cover of the controller around 180 deg. It sits on an angle pointing forward.
    GU IV 2006 4.2 TDi wagon
  7. The Following User Says Thank You to Rip'n'Shred For This Useful Post:
    Nov 2011
    Brisvegas Northside
    Installed mine yesterday,only took about 45 minutes it was pretty easy. Heaps of room inside the bullbar.
    I am yet to mount the controlbox though, its currently sitting inside the bullbar top recess....trying to workout what I want to do.
    I also will have to get a die-grinder out and modify where the rope exits the hawse, its currently running from the bottom of the winch and over the steel bar.
    Hopefully just grind the steel down on the bar, and maybe need an offset hawse....wont be hard.
    Pretty happy with the kit, had everything required including longer mounting bolts. I stripped it down and had a look inside,also rotated clutch lever 90 degrees.
    Its not hard to uninstall,so its not going to be hard to maintain regularly. Hopefully get to give it a work out soon.
    CHeers
    Dave
    99 GU 2.8 TD
    Brisvegas, QLD
  9. The Following User Says Thank You to robbo0001 For This Useful Post:
    Tonks (12th July 2012)
  10. #7
    ACT
    G'Day Robbo, Do you have the factory Nissan steel bar, if so just rotate the winch so the motor is passenger side & gear box is drivers side, then the cable will come off the drum at the top and will be the right possy for the Hawse.
    Cheers Tonks.
  11. #8
    Nov 2011
    Brisvegas Northside
    Cheers Tonks.. Will have another look today.
    Would removing the rope and spooling it over the drum, instead of under achieve the samething?
    Does it need to pull from under the drum?
    Dave
    99 GU 2.8 TD
    Brisvegas, QLD
  12. #9
    ACT
    Robbo, i phoned Tigerz11 and they knew straight away that i had a patrol with a nissan bar and said flip the winch over as i explained, if you re spool the rope, in will be out & out will be in,
    Cheers Tonks
  13. The Following User Says Thank You to Tonks For This Useful Post:
    robbo0001 (12th July 2012)
  14. #10
    Aug 2011
    Capalaba
    yep forgot to mention put the gearbox on drivers side and motor on passenger
  15. The Following 2 Users Say Thank You to Gas_Guzzler4800 For This Useful Post:
    robbo0001 (12th July 2012), Tonks (13th July 2012)
