Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Fixed our noisy AC/Heater fan and leaky duct work.
    Expert ripper's Avatar
    Leeton NSW
    It was a nice surprise to find how easy it was to fix the noisy fan.
    Three screws, a vent hose, and one wiring clip which came apart easily.
    Here's the problem :-)
    1989 GQ LWB Wagon, TB42 Petrol/LPG Auto. Bought Dec 2010
    Jul 2010
    Waterford West Qld
    Can't leave them in there .........
    I'm bloody halarious I know
    Hehehehee.
    Tim
    Oct 2010
    cool nice to have an easy one once in a while.
    Cheers Mike
    Leeton NSW
    This is a beginners guide. Anyone with a bit of experience wont need it.
    The AC didn't seem to be blowing much air, when I looked under the dash near the passengers foot well I could see why.
    There was a big gap between the fan housing and the AC evaporator housing where there should have been a seal. Heaps of air leaking out before it got cooled.
    I forgot to take a before photo so retouched this one to show the problem.
    While fixing the noisy fan I took the chance to remove the bottom half of the fan housing which let me fix the gap. Access is easiest if you remove the scuff panel from along to floor where the door closes, then remove the kick panel from the side of the foot well. This lets you get at all of the screws which hold the lower part of the fan housing.
    I found more rubbish in this part of the duct work.
    To fix the gap I got some concreters expansion joint which has a 10mm strip along the top which tears off easily. This gives you a piece of foam which is about 10x10mm. Added some silicone to keep it in place and it was just right for the job.
    Only needs silicone on one side of the foam. It keeps everything in order until the fan housing is put back in place.
    All done except for putting the fan in it's housing.
    Finished.
    Not hard to do, well worth the effort.
  5. The Following 4 Users Say Thank You to ripper For This Useful Post:
    MC97GQ (20th April 2012), nismine01 (19th April 2012), vixim (24th April 2012), YNOT (12th December 2010)
    Leeton NSW
    Slow typer aren't I
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Top job mate and well done for posting it with photos ... none of this process let's gas escape then (stupid question , but I thought you couldn't mess with the evaporator without losing gas??).
    Leeton NSW
    Nah, it's just the duct work. No gas involved. You can see the evaporator but you don't need to touch it.
  9. The Following User Says Thank You to ripper For This Useful Post:
    Bigrig (12th December 2010)
  10. #8
    Oct 2010
    Quote Originally Posted by ripper View Post
    Bootiful - thanks mate ...
  11. #9
    Leeton NSW
    Just keep the hammers in the toolbox with this one Bigrig
  12. #10
    I had the same problem in my last GQ, fixed it in a similar way. Check for a gap on the other side of the evaporator housing as well.
    Tony
