Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Rear Light Kits
    Rear Light Kits
    Anyone found a kit to get the redundant rear lights working ?
    My next project is calling.
    Expert dan&tamspatrol's Avatar
    brisbane
    http://www.ebay.com.au/itm/Nissan-GU...item5891570ed8
    try these if you want to look ur self put gu patrol lights into the ebay search bar
    Feb 2012
    Just found and purchased these Nissan GU 4 04-10 Patrol New TailLights FULL Functions! from www.carsrus.com.au.
    $155 for a pair and wiring harness.
    Hopefully they do the job. will feedback when i recieve them
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    Hi Paul, I have same tailights from ebay , yes there are ready to go for fitting ,passager side just plugs in , but driver side on my Ti 98 I had to do some wiring as there nothing there to connect , which was ok as there a rubber gomit just below the inside of rear cabin that you can feed the stop/tail and blinker wires from the bumper lights harness, hope this helps . cheers Alex p.s. lens unit do have big slot globes ,the same sharp as dash light globe , hmmm
  5. #5
    Quote Originally Posted by paulvdw View Post
    The wiring harness they are talking about would be the wiring shown on the back of the light. I doubt it would be the actuall harness itself which is needed for the earlier trolls. I'm looking at doing the same as it's got me beat why they go to the trouble of making a car with dummy lights in it... But I am thinking of stopping past the wrecker and getting the actual rear harness assemblie of a later model car so its all done properly. I really just CBF'ed making one up.
  6. #6
    Expert scotty83's Avatar
    Apr 2011
    Hillcrest, QLD
    Quote Originally Posted by altech View Post
    I ran them across the back door. Under the carpet and plastic strip. saved me having to go outside through grommits.
    Scotty B | Take it Off Road or Take it Back
    3.0L GUIV 2005 - TIG Welded Intercooler, NADS, Redarc Dual Battery, Additional rear power socket, 2" Lift (Ironman constant load foam cell), Electronic Trailer Brake Controller, Steel Bullbar, 12,000lb Winch, UHF
  7. #7
    Thanks guys - Has anyone done this on 09 GU - as i haven't checked if the original harness plug is still there, I would think it should be just haven't checked yet.
    As musdski said i might also see if a late model nissan has the same connector then i could just modify to fit a patrol.
  8. #8
    Nov 2011
    Rupanyup, 3388, VIC
    Quote Originally Posted by scotty83 View Post
    Hi Scotty, I did that for the reverse light , did you connect the right side blinker as had got that wire from bumper cheers Alex
  9. #9
    Patrol Freak hekarewe's Avatar
    Feb 2011
    springfield lakes
    i got mine from carsrus over 12 months ago and they are great work a treat and good value for money.
  10. #10
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    I need to look at something similar but would need an aftermarket "Y" frame wiring harness made up to plug into OEM wiring so that the tail lights and the bottom set on my kaymar bar together
    www.swat4x4.com
