Results 21 to 30 of 40
Thread: Stupid Plastic Radiator
    Wodonga
    Quote Originally Posted by putin View Post
    hello, I like it!! is it easy to replace? did you pull off the fan before? I'd like to do the same job because I have exactly the same problem, do I need some special tools? any suggestion is welcome, I'm not so expert. ta
    Have not done the radiator in the Patrol before. The clutch fan is usually better left alone. removing the radiator requires no special tools. Usually sockets, spanners and screwdrivers are all that are needed to complete. That is my experience from many changeovers in other vehicles. If you have a thermo fan it is better to remove it first.
  2. #22
    Sunny Coast
    any suggestions on a reputable place to purchase an aluminum radiator? cheers
  3. #23
    Expert mick.'s Avatar
    Newcastle (NSW)
    I've had one of these radiators in my Patrol for about 5 months now and it's going well. Mine has the auto cooler in it also. Before I fitted this I bought one from a radiator shop which was plastic like the original which started leaking after a week which was then replaced again which it then did the same thing so I got my money back and bought one of these.
    http://stores.ebay.com.au/asifactorydirect
    Cheers Mick.
  4. The Following User Says Thank You to mick. For This Useful Post:
    twisty (11th April 2012)
  5. #24
    Gladstone
    Yes they look the goods. I am going to fit one before I head out west in September.
    bazza
  6. #25
    Feb 2014
    Hi guys,
    I have only recently joined this forum but have had my 98 tb45 for 7 years and now have replaced the radiator for the second time, first time with a 2 core with plastic tanks and last week with a 3 core with welded tanks and i had trouble towing my caravan on saturday with it overheating and i only had driven 5 kms, any thoughts on this would be appreciated as i am leaving to go around australia mid march and need it to be fixed before we leave
    David
  7. #26
    Thomastown, Melbourne
    6 Post(s)
    Quote Originally Posted by Codman View Post
    Hi guys,
    David
    Mate it is customary to head over to the intro section and say gday and tell us a bit about yourself before posting questions... polite and all!!!
  8. #27
    Feb 2014
    Sorry will do, thanks for the heads up
  9. The Following 3 Users Say Thank You to Codman For This Useful Post:
    BigRAWesty (10th February 2014), Bloodyaussie (10th February 2014), Stropp (10th February 2014)
  10. #28
    Patrol God Stropp's Avatar
    38 Post(s)
    check your thermostat mate
  11. #29
    Feb 2014
    Yep thanks done that, found that the thermostat was also buggered so have changed that now just need another hot day to give the car and van another run up the western ring road craigeburn hill to see how it goes
    Cheers thanks
    David
  12. #30
    My mechanic had a long saga with a replacement radiator in a TD42 ute, all alloy job and it simply wouldnt cool as well as original. Still chasing refund
    Can buy new tanks for them, top one seems to give issues with heat and age.
