Results 1 to 10 of 17
Thread: rear wiper leaking
    brisbane
    rear wiper leaking
    a mate of mine has a 02-03 gu patrol and when u park up a hill even as low as 4deg faceing up the,rear wiper water outlet leaks to the point it will drain the whole tank out. has any one had this issue could this just be a bad seal on the wiper pump?
    There is a little check valve in the line near or in the large barn door. This is your culprit
  3. The Following 3 Users Say Thank You to Mmarcuss For This Useful Post:
    AB (25th March 2012), Cowboy (2nd April 2012), megatexture (2nd April 2012)
    brisbane
    ahh ok will let him know cheers !
    Wollongong
    Quote Originally Posted by Mmarcuss View Post
    Yep, spot on.
    Ours was doing the same thing, changed the check valve, and all good.
    Only problem was at the time (3moths ago) Nissan didn't have any, so had to order in....
    Rick
    Life is like a box of chocolates
    Expert lufkin's Avatar
    Victor Harbor, SA
    this is the part that needs replacing www.atocauto.com.au/proddetail.asp?prod=28628_D2700
  7. The Following 2 Users Say Thank You to lufkin For This Useful Post:
    Cowboy (2nd April 2012), megatexture (4th April 2012)
    Feb 2011
    Kerang, Victoria
    Is this the same on the early GQ Patrols/Mavericks also?
    Ben
    Expert billyj's Avatar
    gordon
    behind the drivers side body tail light on a gq
  10. #8
    Feb 2011
    Kerang, Victoria
    Thanks Billyj,
    I will have a look for it.
    Ben
  11. #9
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    Check ebay. they are about $13 plus postage. But yes this is a problem.
  12. #10
    Hardcore
    central coast nsw
    After reading this post yesterday I removed mine as it leaked.
    Checked , yeah flowed in both directions, given me the sh### for a while now no water.
    Hand pump spray bottle with car wash in it, few squirts either way.
    Flushed under tap.
    Still no good.
    Have a bottle of hydrochloric acid.
    Dipped a small round file in and applied directly in valve a few drops inside
    Giving 1 minute and the valve spring a little work /prodding with file end.
    flushed out again with water.
    hold valve up hard against running tap with file inserted to work valve internals .
    re-flushed with pump bottle car wash squirts and flushed again with clean water.
    FIXED, for about 5 cents and 5 minutes
