Results 1 to 8 of 8
Thread: Q, for all fabricators.
    Advanced GQ snail's Avatar
    South Brisbane
    I am looking at making my own roof racks, I want to buy all material myself and weld it up, however I want A metal frame with aluminium security mesh as top. I have been told, and researched that these to metals can not be welded. Is this 1 -> True or false 2 -> Is there a way I can join join them if welding not an option?
    Saving Yotas Since Creation
    Feb 2011
    Shed
    45 Post(s)
    Ali melts at a low temp and steel at a much higher therefor welding probably isnt an option
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    Nup, ya can't weld ally to steel, end of story.
    If you want to make the rack using steel you will need to bolt the mesh on.
    Cheers, the ferret.
    Hardcore macca86's Avatar
    Jun 2011
    Brisbane again! whoo!
    as the ferret said bolt or rivet also steel to aluminium will cause corrosion as the two metal react with each other to form oxides you'd need to have rubber packers between the two different metals. getting a sheet of wire mesh would be the go still light and strong and can weld it to the steel 50 x 50 or 100 x 50 squares with 3 mm wire. Order from a steel merchant to cut costs like steel force onesteel vulcan or anyone else. 32 x32 x 3 shs or 40 od pipe or similar would be the size you need
    Such is the rule of honour.
  5. The Following User Says Thank You to macca86 For This Useful Post:
    GQ snail (25th March 2012)
    Palmerston North NZ
    If you are going to use expanded steel mesh as a floor make sure you weld every single piece around the perimeter or add an edge cap of some sort to prevent it ripping the sh!t out of any thing that comes into contact with it, swags, tents, tarps etc.. I've seen tool cages covered in this cause litterally thousands of dollars worth of damage. Use welded square mesh to be safe.
  7. The Following User Says Thank You to The Tank For This Useful Post:
    South Brisbane
    Quote Originally Posted by macca86 View Post
    Cheers,
    was thinking that wire mesh was going to be go, cheers for sizes, was wondering what would be best.
    Jun 2011
    you don't neet too big a gear as your roof is rated to carry a certain weight not sure maybe someone can tell you but that weight has to be your rack and luggage combined try keep the weight down
  10. #8
    I believe the roof is rated to carry 110 Kg max
  11. The Following User Says Thank You to Clunk For This Useful Post:
    macca86 (25th March 2012)
