Ok I did the self diagnosis this morning (5 times and once just then at lunch) it says the problem is: inhibitor switch, power shift switch, kickdown switch or idle switch circuit is disconnected or the control unit is damaged.
Anyone got any clues as to which it might be? Or which is the easiest to check? Haynes Book has info about inhibitor switch and power switch only.
Lucas
