Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Fitting pyro guage to dump pipe
    Advanced scrubrat's Avatar
    Oct 2010
    Geraldton W.A.
    Would anybody have a photo they could post of exactly where the pyro probe gets fitted.I'm about to fit an autometer pyro guage to the patrol. Also,would the supacheap auto oil catch can kits be sufficient to use,I know the provent 200 is the preffered choice and you only get what you pay for but it should do the job.
    Scrubrat
    I don't have any photo's but you want the probe for the pyro mounted as close to the turbo as possible. There are 2 different mounting methods, one uses a hose clamp arrangement and is an easy DIY job, the other requires a fitting to be welded onto the dump pipe. I'm not sure what the autometer pyro's use.
    Personally I think you would be wasting your money fitting a supercheap catch can from the reports I've read they just don't filter out enough oil mist to be confident your MAF sensor will stay clean.
    Tony
    The autometer ones come with both fittings. They have the probe which you can drill a hole in the dump pipe to suit, insert the probe with a ceramic washer and clamp to hold in place which is all included or it also comes with a nut that can be welded in the pipe.
    I did the ceramic washer, probe and drilled hole which worked fine for me.
    As Tony said mate, easy DIY job.
    Oct 2010
    Geraldton W.A.
    The autometer pyro has the clamp and ceramic washer so hopefully won't be to hard of a job to install.I've heard the heat shield is a bit of a bugger to get off tho. As for the catch can,I have heard that a complete kit is up around $300,but then again it's a small price to pay for piece of mind.
    Cheers tony
  5. #5
    This might help you a little bit on the pyro. I forgot to do a detailed post about the install but there is some small info there about it.
    http://www.nissanpatrol.com.au/forum...ro+boost+gauge
  6. #6
    How's the serenity boots's Avatar
    Sep 2011
    The heat shield on a zd30 is a pain to get off . not much fun at all.
  7. #7
    Oct 2010
    Geraldton W.A.
    I'll go with the clamp and ceramic washer,sounds like getting the heatshield on and off is the hardest part of the whole job.
    Thanks guys
  8. #8
    Quote Originally Posted by scrubrat View Post
    Thanks guys
    It is a bit of a pain to get the heatshield off but it's not too bad.
    Tony
  9. #9
    Expert Leighw85's Avatar
    Sep 2011
    Perth
    what i did mate. Took it to an exhaust place. But its hard to find one that wanted to do it.
    And get a new 2 1/2 inch dump pipe, with the pyro bung in it. That way when i replace my exhaust, its also a lot less hassel
    cost me about $350 installed
  10. #10
    Oct 2010
    Geraldton W.A.
    As i'm planning on doing quite a few things to the patrol while she's off the road,I have to keep costs down . I can't really justify paying $350 just for the sake of one little hole, so it's skinned knuckles and a few choice swear words.
