Page 112 of 212 FirstFirst ... 110111112113114 ... LastLast
Results 1,111 to 1,120 of 2116
Thread: Merged - Deleted "Wanted"
  1. #1111
    Banned
    Quote Originally Posted by Bigrig View Post
    Did that old mate - they recommend original units (apparently you "simply" bend the arm to suit and that is the recommended and most common approach?).
    Can't find a second hand one, and being mines a 92 model the price difference is huge- $87 for a Pre 92 model, nearly $500 genuine for a post 92 model ???? Appreciate they had bigger lines in them, but what would that matter to a sender?? Or should I just be getting an earlier model one considering it's going to be bent to suit anyway???
    I think the post 92's actually had smaller line size, 7mm from memory as apposed to the pre 92's 10mm line size...
    The price difference I expect is the post 92 run an "in tank" electric fuel pump that is located at the bottom of the fuel pick pipe which it part of the sender unit so that may be the reason for the difference in the pricing, however unjustified.
    Just a point to be aware of here.... You will more then likely need a higher volume electric pump over the STD so if you go new try to get a sender without the pump. It might bring down the price a bit if you can, but check it out with your blokes to see what combo they intend on using first.
  2. #1112
    Have you checked to see how similar they are to r31 skyline ECU's?
  3. #1113
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    150 and a case of bourbon you can have my one
  4. #1114
    Nov 2011
    Townsville
    GQ Roof rack and Cargo barrier
    Hi guys I am looking for a tough preferably alloy roof rack for my GQ and also a cargo barrier steel milford type
    Cheers Andrew
  5. #1115
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Quote Originally Posted by patch697 View Post
    Thanks mate - getting a Wallbro High Performance pump with no sender ... scary pricing for a couple pieces of steel and some electronics!!
  6. #1116
    Oct 2010
    Quote Originally Posted by toddrhind View Post
    Haha ... Ta mate!! I think!! lol
    I'll keep hunting first though but will keep your offer in mind!!
  7. #1117
    Oct 2010
    Quote Originally Posted by gec View Post
    No pressure Mate, It is the holidays after all, and what good is a holiday if ya cant sit on ya date lol.
    Haha - thanks boss ... too much sitting on the date though I reckon - might be time to pull the finger out!!
    I'll get it in the morning when I drop it off to the mechanic.
  8. #1118
    Aug 2010
    17 Post(s)
    so are you just after a sender itself not the whole unit???
  9. #1119
    Oct 2010
    Yes sum boss ... buying the pump elsewhere (PetroJect in Brissy - top mob an really seem to know their stuff - getting the high flow injectors from them also),
  10. #1120
    Banned
    The price of performance is never cheap old mate.
