hi guys, i was just wondering how hard it is to change the seals on the diesel pump? and if there's any tricks to doing em?
what will happen if i keep driving it, or should i not drive it till its fixed???
can anyone help?
Sorry matie, i know jack About cats - It's pretty late up here in Sunny Queensland and all the old farts (LMFAO) who more than likely will have an answer for you are sleeping like the little angels they are![]()
Not to mention I'm way to old to be awake at this hour LOL
NISSANS Rulz .... "Amelia" the 2006 4.2ltr Patrol Ute & "Seamus" the 2008 3ltr Patrol Wagon
haha thats gold, but true it is abit late 4 the oldies, cheers anyway buddy!![]()
Hi mate, the top seal is fairly easy and doesn't require the removal of the pump. The other seals though.....Bit of a pain!
Whereabouts is it leaking from?
I drove mine for months with it leaking but It's better to fix it early. Degrease the pump, get it sparkling clean and try to identify which seal is leaking...
bobby-didge (2nd April 2012)
hey AB, it looks like its leakong from the bottom oval shaped plate, that has two bolts in it. its only just started leaking and its not leaking too bad yet.
It started leaking when one of my mates pumped the diesel primer, would that have cause the seal to go??. ill give it a clean like u said, and just hope its the top one! cheers for your help AB
bobby-didge,
I thought I would post a link to a thread I started a while ago, it might help you with your problem if you haven't sorted it yet.
Fuel Pump Leak
Hope it helps
Mark
Proud former owner of a 1997 White GQ TD42 Patrol Cab Chassis with an after market turbo, now with over half a million k's and still going strong, that's had a heart transplant and now not owned by me
