Results 1 to 10 of 10
Thread: oil filler cap
    Patrol God wildgu6's Avatar
    Sep 2010
    Adelaide S.A
    oil filler cap
    Hi guys, Dumb Q' time,
    Can anyone tell me why the trol is blowing oil residue out the oil filler cap, only just noticed it when lifted bonnet to replace radiator overflow tank, not sure how long been going on. Also quite a bit of oil residue in the intercooler as well.????
    Cheers Pete
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    Sound like you might have a little blow-by
    What is Blow-by?
    Blow-by occurs when the explosion that occurs in your engine's combustion chamber causes fuel, air and moisture to be forced past the rings into the crankcase. Your engine's rings must maintain an excellent fit in order to contain the pressure.
    The causes of blow-by: wear, soot and deposits
    As rings and cylinder liners wear away they are less capable of maintaining this seal. Consequently as a car ages the amount of blow-by that occurs can increase.
    Soot and deposits left over from incomplete combustion that collect on the rings can also inhibit their seal worsening blow-by.
    The effects of blow-by: loss of horsepower and oil contamination and dilution
    Blow-by inhibits performance because it results in a loss of compression. When the expanding gases slip past the rings they cannot as effectively push the piston down and make the vehicle go. As a result the car will have less horsepower. This also results in a loss of fuel economy.
    When the fuel, air and moisture slip into the crankcase they contaminate and dilute the oil in the crankcase.
    Among the many gasses in your compression chamber are unburned fuel, moisture, sulfur dioxide and soot. Once these gasses slip into your crankcase they can dilute into your engine causing great damage.
    The detergents and Molybdenum Disulfide work together to clean the soot and deposits off of your rings allowing them to better seal the combustion chamber.
    The Moly fills the crevices in the cylinder walls providing a better seal:
    Less blow-by means less contamination, less fuel dilution, and more power.
  3. The Following 4 Users Say Thank You to Dhuck For This Useful Post:
    AB (19th October 2011), albi (20th October 2011), Finly Owner (20th October 2011), wildgu6 (19th October 2011)
    Sep 2010
    Adelaide S.A
    well thank you for that Dhucky, Much appreciated mate,
    So what preventative measures should i take to avoid a costly outcome.
    Feb 2011
    Brisvegas
    do diesels like petrol engines have positive crank case ventilation? If they do would be worth checking the valve and the pad inside the aircleaner.
  6. The Following 2 Users Say Thank You to Silver For This Useful Post:
    albi (20th October 2011), wildgu6 (19th October 2011)
    Nov 2010
    Crap Weather State
    5 Post(s)
    Quote Originally Posted by wild98 View Post
    The only fix I know of is new rings. But I am not sure if there are any other fixes for a diesel.
    Quote Originally Posted by Silver View Post
    Would not have a clue. I have only ever played with petrol and methanol engines.
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    Mate, for starters, check the seal on the cap. check operation of the PCV system, If it has only just started doing this all of a sudden, it may be something simple.
    But as DHUCK said, it's usually an indication of blowby, this can be caused by gummed up rings, glazed bores, broken ring, or just plain worn out.
    Glazed bores is caused by not working it hard enough.
    Cheers, the ferret.
  9. The Following 2 Users Say Thank You to the ferret For This Useful Post:
  10. #7
    Sep 2010
    Adelaide S.A
    ???????????? not sure mate will look into it
    Quote Originally Posted by Dhuck View Post
    Bugger, knew you were going to say that, thanks guys
  11. #8
    Banned
    The "O" ring in the oil cap could just be screwed.
  12. The Following User Says Thank You to patch697 For This Useful Post:
  13. #9
    Quote Originally Posted by the ferret View Post
    Or go out with a smile Wild and see if ya cant clean her out mate
    on a side note hope it is not something terminal mate.check your PCV and maybe think about a Provent or something... Not a Solution but might be part of your management regime.. good luck
  14. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  15. #10
    Sep 2010
    Adelaide S.A
    Cheers, the ferret.
    Thanks Rod, will have a look, as said only just noticed it happening, and last time i topped up oil it felt like cap didnt screw on as usual.
    Tried it several times with same result, but always in a hurry.
    Might sus it out a bit closer, hopefully thats all it is.
    As for not working hard enough...Ha I dont think thats the prob' but thanks for the feedback mate.
