Results 1 to 10 of 20
Thread: Snapped off Glow Plug
    Advanced _Greg's Avatar
    Sep 2011
    Just a quick question to anyone that has had this happen to them. I am putting in the 11v plugs from the RD28eti engine into the RD28T (which has 6v multistage glow plugs standard), and i snapped one off when trying to remove it. has anyone got any tips for removing this without damaging the head?
    Picture Below.
    Thanks in advance
    Greg
    Banned
    Quote Originally Posted by _Greg View Post
    Picture Below.
    Thanks in advance
    Greg
    I've not had the pleasure myself but looking at the pic I'd give an easy out a go & maybe some gentile heat if its stuck good.
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by patch697 View Post
    X2 with the easy out
    Sep 2011
    i've got no problem with the heat, but how do i get a grip of it?
  5. #5
    Sep 2011
    Thanks, i get it now, the "easy out" is a screw remover. Sorry for the thick headed response.
  6. #6
    Feb 2011
    Shed
    45 Post(s)
    Ann easy out requires you to drill the right size hole for the easy out then insert the easy out. these can be a wedge shape or left hand threaded looking bolt, as you unwind the snapped bolt (gripping the easy out) the easy out tightens in the bolt SOMEONE HELP ME EXPLAIN CLEARER :-)
    OOPS im too late :-)
  7. #7
    Banned
    Quote Originally Posted by growlers71gq View Post
    Im tipping he's found it on the net mate by the looks, so your bacon's safe for now......lol
  8. The Following User Says Thank You to patch697 For This Useful Post:
    growler2058 (27th September 2011)
    Sep 2011
    yes, thanks. I re-read the post and found the odd wording - "easy out" - googled it and found what it is. I'll swing past repco tomorrow and find one - thanks again.
  10. #9
    Banned
    They normally come in a small set & take my adivce here " don't go for a cheap set" (I find Repco tools quite good myself) & take your time doing the job cos these things are tooling steel & if you snap one off, its all over red rover....If you get my drift.
  11. #10
    Expert the godfather's Avatar
    Mar 2011
    Piara Waters, WA
    Defenition of EASY-OUT: A tool you break when removing broken bolts or screw. Also impossible to drill.
    Sorry, I couldnt resist. Broken anythings are a pain. I hope it comes easily for you Greg. Good luck.
