Results 1 to 7 of 7
Thread: Engine Buzz??
    Beginner stump05's Avatar
    Aug 2011
    Wagga Wagga
    Engine Buzz??
    Watcha!
    Took "The Brick" on our first highway roll. Wagga to Bathurst to Sydney then home. Real pleased with the fuel consumption (1999 GU 2.8 litre TD) coming back in at 11litres/100k but...had what I would call a very tight vibration which can be felt through the steering wheel, gear stick and even the seats. Feels like a heavy buzz and is more noticeable in the lower gears. I tried coasting with the clutch depressed to see if it is wheels/suspension/sterring and the vibration went when the clutch was depressed. Still pulls fine and powers up the hills etc so I'm just wondering if anybody else has/is experiencing this?
    Is it normal or an issue? Cheers in advance - Stump - Rock On!
    Hey Stump, is the vibration only in lower gears, lower revs and not at high?
    This is caused by general engine vibrations which happens on my TD42 all the time and shutters through the whole car.
  3. The Following User Says Thank You to AB For This Useful Post:
    stump05 (27th September 2011)
    Banned
    Quote Originally Posted by stump05 View Post
    Watcha!
    First pot of call would be to go check your uni joints.
    Sounds a bit like one to me.
  5. The Following User Says Thank You to patch697 For This Useful Post:
    Aug 2011
    Wagga Wagga
    Thanks AB and Patch697 for the reply. I had a thought tonight driving in town that I had a new single mass heavy duty clutch put in just after I got it. Could this be responsible for the vibe. It is through the entire rev range AB and in all gears just not as pronounced in 4th or 5th doing the legal limit of course.
    Jul 2010
    Waterford West Qld
    I agree with Paul, also suggest checking wheel bearings are not over tight and greased.
    Tim
  8. The Following User Says Thank You to Finly Owner For This Useful Post:
  9. #6
    Sep 2011
    Yes check the wheel bearings front rear and your uni joints.
    I had a similar problem and it ended up being the water pump.
  10. The Following User Says Thank You to suvrd28 For This Useful Post:
    stump05 (3rd October 2011)
  11. #7
    22 Post(s)
    Wheel bearings will still make a noise if the clutch is in or out. You have recently had clutch work done I'd be looking there first. I would then follow the same path as suvrd28
    96 GQ coil/Cab
    08 G6eT
  12. The Following User Says Thank You to Ben-e-boy For This Useful Post:
