Results 1 to 10 of 101
Thread: My attempt at installing a LOKKA brand Auto locker
Threaded View
  1. #6
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    Quote Originally Posted by growlers71gq View Post
    I will do just that mate, try and post something useful on the forum rather than my usual dribble hahahahahaha. I already have the axles out as have just done wheel bearings seals and swivel hub bearings and seals. Tonys put a brilliant post up re this part so I'll start from removing front prop shaft and diff centre and take it from there. And yup its the front diff
    Cool, perhaps you could you put a link to Tonys info, im sure it will be usefull for others who discover this thread, and are wanting to do the job starting from scratch ?
    Or......Maybe Tony just needs to fit one in my rig, only so i can take detailed pics from the start, all the way through (ha-ha)
    Would also be interested if you could measure your approx turning circle when locked in 4wd with your open centre now (obviously need to be on grass, dirt or sand etc), so it can be compared after lokka install.
    I also assume you have manual hubs ?, im interested to get the chance to confirm/dismiss the auto hub problems when used with lokkas (ive heard mixed reports about UN-locking issues)
  2. The Following User Says Thank You to 04OFF For This Useful Post:
    growler2058 (27th August 2011)
