BigMav
This is my advice mate, steer clear of the return to centre steering dampner they only put more pressure on your other steering components, you have been quoted with castor bushes so no drop boxes needed. You really want to use standard nissan rubber bushes and drop boxes instead of the castor bushes though. Also get rid of all those poly bushes they want you to buy. There really is no replacement for genuine rubber bushes in all cases. I doubt you need all those bushes to be replaced either. Transmission spacer is not required either. Personally I'd stay away from the shop that is trying to flog all that gear off to you. Also superior engineering gear is excellent stuff but a little pricey.
