QLD Members Working Bee - Expression of Interest
EDIT: Location, date and time all locked in as per below.
Torq4x4
Unit 3, 82 Johnson Road
Hillcrest
9:00am start (please try to be there earlier to organise cars and schedule).
Work gear please guys!! It is a licensed workshop, so sandshoes as a minimum if not working on the cars, and steel caps/appropriate gear if you are (especially for those intending to weld).
Bring all tools that you have for the job you wish to have done. Doesn't matter if you don't have everything as others are bringing theirs (we should have no lack of equipment), but still bring what you have.
Bring all oils, filters and fluids you require if you are wanting fluid replacement - engine, transmission, transfer, diffs, brakes, power steering, fuel.
Bring all parts you want swapped in/out unless you intend to buy them from Torq4x4 or SuperCheap or something when you arrive.
Example:
I am bringing full tool kit (suits just about every nut, bolt, circlip, etc for GQ/GU Patrol), arc welder (gloves, mask, sticks etc), tap and die set, electrical kit (connectors, fuses, wire, etc, etc), HTB grease, grease gun, and assorted other gear.
Howdy
as per the other thread, looking to lock in a day and location for another day of fun in the sun and working on the rigs. Thinking Saturday 24th September or Saturday 8th October? Thoughts
If people who are interested could list down the top two things they want done, what I propose we do is work out who's coming, what talents we have amongst that group, and as a result, pick 3 rigs out of the list to have specific work done - would obviously still like everyone to show up even if your rig isn't picked as a show of support for the process (bit rude only shoing up to get your truck done and then doing the Harry Holt!).
Sooooo ... who's up for it??
POLL ABOVE - mulitple choice allowed so select both if you can come, and what you are good at!!!!
I'll start - I'm in, don't care where - want to do the rear seal on my transfer case (which I can do, but would like extra hands); and/or a dual 12 volt outlet in the very rear cabin.
