Hello people.
Should a laptop battery last long enough to watch a 2hr DVD?
The one we've got is a few years old but nothing wrong with it. Even got Windows 2007 home edition.
Any ideas on the price of a new battery?
Thanks.
Hello people.
Thanks.
you may be lucky Rosscoe, my works dell laptop can do it, but the missus Toshiba laptop only lasts about an our on battery playing dvds......................... not too sure on prices on batteries, havent really looked into it mate, but I reckon if its for when your out and about camping, you'll be better off with an inverter..................... what make and model laptop have you got?
Try this Site
http://www.au-electronics-home.com/i...FUYDHAodzmf_WA
I have a Dell 1720 and purchased a Battery for $70 odd that I have charged up and take with me on trips.
Small cost to have a Backup and I also have an Inverter so covered for most situations
My work HP laptop has 2 batteries and I get about 6 hours of run time if I'm using it. Will last all day if the screen is down. These batteries are only new after I got down to less than an hour run time on the old batteries. I hope Dell batteries are cheaper than HP, the 2 new HP batteries cost $500!
Side note, this is not my original laptop, the original died a few weeks after I got the new batteries but I swapped the new batteries over.
The battery in my phone died earlier in the year, I fitted a new battery and a few weeks later the phone died.
I fitted a new battery to the van not long ago........................
Tony
What make and model is it Roscoe?
I just bought some new Dell batteries for a 1520 out of Hong kong for $28 delivered. If it is an older Toshy Sat Pro and you take the battery out you can run it off 12 volts BUT don't let the voltage drop down to much. I got away with that for years.
The best way for camping IMHO is a voltage converter (12 volts input and 13.5 15 17 etc selectable output) that plugs straight into any lappy and run off the Camping Power... Next best (but very inefficient) is to run an inverter and the 240 volt adapter into the Lappy.
Or... you can spend some bucks and get top of the wozza extended batteries for some makes but BIG bucks relatively speaking.
Running a DVD is pretty much the most power hungry application you can have so you will need either good lappy batteries or use the Camp 12 Volts/Genny or whatever
yep thats what I meant, a converter, not an inverter, thanks ET
One thing that kills a laptop battery is running the laptop on the mains with a full battery. If your running your laptop with the mains and your battery is full, take the battery out. It will preserve its life. Newer batteries last a lot longer but that is also because laptop hardware is now a lot more energy efficient than say 2-4 years ago. Most laptops run lithium 6 cell batteries. depending on your laptop sometimes you can upgrade to a 8 cell which will have a lot more life. Movies are hardware and resource intensive which uses up a lot more power than say browsing the web so you will burn up the battery power quicker. As for prices they vary all over the place. Don't always go for the cheapest battery, these can have major effects to the laptop with over heating and unreliable power so either go for an original or something recommended and guaranteed for your laptop make/model.
cheers
Brett
Ok... not all that familiar with them but no bigee as no matter the brand for what you want to do just google " Laptop Car Adapter". These will plug into any ciggy plug and power the lappy thru the same jack as the 240 Volt adapter.
They come either selectable with various DC outputs or if you look on your 240 Volt adapter it will state what Voltage it supplies. You can then buy a Car Adapter that has the same DC voltage.
Here is just one link at random... http://www.top-battery.com.au/Auto-Adapters/
Dick Smith, Ebay, any larger Car Audio Outlet, any Computer supplier like Austins or Storm will all have them
