Brass
Thanks for all the advice guys, really appreciated.
I think my plan for now is:
I have a sparky mate willing to help out this weekend, and we will run the 8 gauge wire to the rear of the vehicle (and set up all the anderson plugs, fuses, etc). This will give me a chance to test the battery with the Engel fridge for 12-24 hours. If it holds its charge roughly as expected, then great. I'll probably go to battery world after this as well to see about that health check just to confirm. If it does not hold charge, then its an obvious replace.
Either way, Cuppa and Yetti's Beast make great points that it is probably not enough should a literal rainy day occur (and I do not want to leave yet). And while 50-75% of the trip will be at least somewhat near civilization, a minimum of 25% of it will be completely out in the bush (eg. Plan to do at least 7 days across the Gibb River Road, and would love to just sit in Cape Range national park, or Karijini for a few days without moving)
So this leaves me with 2 options in my mind. Either get a new 120-140AH battery to replace the current one (the obvious choice should the current battery turn out to not hold charge). or I could get a 100-140AH AGM to throw in the back that is completely detached and only charges via solar.
For the first option, does anyone have any recommendations on deep cycle batteries (AGM or wet) that can live in the engine bay half decently. Was busy today, so did not have time to measure what the current tray can hold.
For the second option, I would likely have a setup where I could swap anderson plugs to power the fridge via the front aux batter, then switch to the rear aux battery. Does that seem sane?
I think both these options take Yeti's KISS advice to heart, and involve the least amount of electrical work. It also lets me get some work done this weekend that will not go to waste. As much as I would love a dc to dc charger setup, I cannot find one for less than 250 that looks even halfway decent. And the good ones seem to be at least 500.
Once again, thanks for all the feedback so far. It's been really good, and helped me start to make a better plan going forward.
