Fitting a Redarc TowPro to a GUIV
		Hi guys,
Well I have bitten the bullet and purchased a Redarc TowPro for the GUIV. I did a fair bit of reading and felt the TowPro auto Calibration on the fly was a winner.
So a couple of questions to begin with.
Where has everyone installed the single dial controller? Very interested in pics please, especially in a GUIV.
When I had my alarm fitted the installer fitted the warning light to that little panel on the right side of the steering wheel wheel Cuppa has his.
 Show me where you put it.
Also, I am replacing an old controller. Should it be expected that the wiring colours will be the same? What is the best way to test colours? Does anyone have a list of colours for your towpro.
http://www.nissanpatrol.com.au/forum...017/09/155.jpg
		Wiring up is as per the instructions, is pretty straight forward.
Based on advice from redarc we used minimum  30amp wiring for the black and blue, and 20 amp for the brake input - which retrospectively was possible major overkill -- I think we ended up using mostly 6mm based on what we had available.
I installed the controller on the pop out panel above the mic - good position for viewing  and also access for driver abs passenger if required.
The unit was installed under the steering wheel on the panel - the set of 4 screws on the right hand side.  Other set of bolts is for my lock up torque converter.
Instructions from redarc say that it doesn't matter what orientation the unit is it, as long as it's secure and can't move.
http://www.nissanpatrol.com.au/forum...017/09/171.jpg
http://www.nissanpatrol.com.au/forum...017/09/172.jpg
If you got any other questions let me know
		I too installed my controller up near the radio for ease of adjustment
http://www.nissanpatrol.com.au/forum...017/09/174.jpghttp://www.nissanpatrol.com.au/forum...017/09/175.jpg
And the box went up behind where the original old brake unit sat under the dash next to the steering wheel.
Very happy with the Redarc product [emoji106]
Oops my photos are the wrong way around lol
		I too had a faulty controller (Tekonsha) so for me it was simply use the existing wiring, both units had the same colors.
They too had gone over kill on the wiring and used 6mm from the battery to the controller and from the controller to the rear. At least we know it can handle the current.
Oh and ps off topic a bit, for those with the original radio with blue tooth and if you ever change it for a new one, you will find the new radio will have a gap around it. The original has foam strips stuck top and bottom, carefully remove them and place on your new radio to give it the factory finish
http://www.nissanpatrol.com.au/forum...017/09/176.jpg
http://www.nissanpatrol.com.au/forum...017/09/177.jpg
Sorry for wandering away from the subject [emoji6] but it was a handy tip I learnt when I changed my unit
