I urgently need some help. I have no low beam on my GU Patrol. High beam works fine. All fuses are fine.
Does the high beam light show on the dash when on low beam? Shake and wiggle the connectors behind the lights. This fixed my problem.
na no high beam light only if high beam is on. Pulled globes out and they are both fine. they worked fine on the way home from work this morning.
hmmm could be a relay issue......
Possibly an issue in the switch itself. I had a similar issue in mine, and a mate had the same in his. Pull the switch off, check the contacts for any blackness, and clean dirty contacts with a bit of fine sandpaper and some contact cleaner. Reassemble and see what happens.
Most likely culprit will be the switch, as it gets turned on and off a lot over a lifetime.
Check for 12V at the globes when you turn on the low beams, and if no voltage, then check the wiring out of the switch
we checked the relay box but there isnt any relays for the headlights, might have to check the switch out tomorrow, thanks guys.
Sounds like a loose wire if its not the switch. Have you been working under the hood?
no i havnt been working under the hood for a couple weeks. ill check the switch out and check voltage at the globes next,
Sounds like two blown low beam filaments, how did you check the globes?
