just found this click on the link
http://www.automatictransmission.com...sp?NewsId=8169
sounds like a good idear dont know cost though
stephen
stephen
Make sure you’re sitting down when you ring for a quote.
Most of us just change the 12 Ohm line pressure dropping resistor for a 1K or 2K 20W resistor which improves shifts for about $5.
I think this is one of Chaz's diagrams. This circuit lets you switch between the factory 12ohm resistor and (in this case) 1012ohm.
http://i758.photobucket.com/albums/x...uit_series.jpg
Tony
hi, does this mod apply to the GQ as well?
Yes it does.
Tony
Yep, that’s the one Tony. I’m still using that setup and have found it useful when doing a lot of low range work. Some times it just shifts too hard with the 1K resistor in circuit, so switching back to the factory 12 ohm job makes it a lot smoother.
http://www.chaz.yellowfoot.org/image..._resistor1.jpg
looks interesting, where is the TCU located and is there a connector on pins 1&2 already with the 12 ohm resistor across them or is it something that needs to be added?
Many thanks
sorry to be dumb, I thought it was the ECU behind the passenger panel. And is the resistor somewhere close by?
Thanks again.
The resistor is on the outside of the firewall where the clutch master cylinder would be on a manual car.
Tony
ah, found mine in a slighly different place on the drivers side inner wheel arch near the firewall! Makes quite a difference unplugging it, so will try a 1k resistor.
ps, if the max voltage across the resistor is 12v, a 1k resistor would need to be about 0.15W min. (V squared / R = 144/1000)
cheers
can we have some pics please when you do this mod BigRig thanks
stephen
did the mod on my GQ. A 3K resistor was a bit too much, gear change from 1-2 was too harsh so settled with a 1.2k resistor. 1-2 ans 3-4 noticeably faster, 2-3 quicker too, but still a bit sluggish. A standard 1/4W resistor worked fine, hardly gets warm.
Not sure if the original position of my 12ohm resistor is standard, but here are some photos showing its location. It was easy just to unplug the harness, fold the legs over on the new resistor and insert it into the harness end connector. A bit of tape over the end wil keep it in place, although you might want to do something more permanent.
I'm planning to be home most of the weekend. How is Saturday arvo for you?
Tony
Hi all,
So what does this mod actually do?
Cadbury
Fitting the extra resistor increases line pressure in the transmission, the result being faster and firmer gearshifts. In some situations faster/firmer shifts may not be desirable, that's why the circuit shown in an earlier post has a switch to bypass the mod and return the transmission to normal.
Tony
In my auto I've noticed a sort of delay/dragging as it changes up through each of the gears - is this the operation that the resisitor improves?
Barney
I ripped mine out - made a little difference to the changes (1000 ohm) mainly second to third, but apart from that, not overly noticeable - something we'll have a lash at again down the track once the new engine is in ...
Hi All,
Thread dig I know, but is there anyone in Perth willing to lend a hand doing this.
OR:
Is there a good write up with pics on how to do this with an 02 GU 4.8l Auto.
getting tired of the crappy shifts.
If you've got the dollars, go the Nomad Heavy duty valvebody. Ive put one in my TB42 GQ and it shifts like a sports car:) A few others that have done it are also very happy with the result. Im in the process of talking a mate into putting one into his TB48
G'day all. My name is shane I have a 2002 wagon st plus 4.8auto 5 speed. I looked for the voltage resistor but cannot find it thanks guys
Has anyone ACTUALLY done this to a 4.8 GU, it seems more like GQ's here?
If so any pics etc?
Thanks in advance
Hi mate i know its been a while since you asked & you might have already sorted it out but ill put my 2 bobs worth in ive got a 98 4.5 gu second owner & i unplugged mine before i left the car yard the salesman had no idea wot i was doin. Mine is mounted on the drivers side firewall on the removable gold anadised plate where the clutch master cyl would be on a manual. Ive left mine unplugged for approx 6yrs now & havnt had a prob with it & im usually towing a car trailer i learnt about this mod with company vehicles i use to work on. Hope this helps
I dont have anything on this anodised plate.......
On my GU, i just keep the auto transmission swich on the centre console in "power" mode, doesn't this do the same thing anyway ?
I dont have a power switch either....LOL
