happygtu
Covo,
You will need to think safety, safety ....
You will need a method of jacking your car up high enough, so that the diff / wheels are off the ground, and you definitely need a set of safety stands under the car as support, just in case something goes horribly wrong - don't want to hear about a squashed Covo ......
I used my highlift jack, which sounds dangerous, but with the correct safety stands, made it quite safe and quite easy. ( Probably the only time the highlift jack has been useful )
PROCESS :
REARS :
Start by undoing the rear shocks, and remove - keeping all the nuts and washers together. ( these need to be replaced anyway but they are handy when you lose a nut/ washer in the install process )
Then undo your swaybar links and remove - keeping all the nuts, washers and links together ( these need to be replaced anyway )
Important.....undo the brake line bolt that holds the brake distribution tee block to the diff ( at the bottom of the flexible rubber brake line to the diff ), and also release the closest clips that hold the brake line to the diff, and make sure that the block is unclipped from the tag that holds it so it can move freely - I normally push it up, bending the solid lines a little , so I know it is clear and it wont catch. ( Place bolt in a secure location, as it will get reused )
Next undo the diff breather from the top of the diff.
FRONTS:
Start by undoing the front shocks, and remove - keeping all the nuts and washers together. The fronts can tend to be a little harder to get the nuts undone and you can lose a fair bit of time getting these loose - you can also twist off the bottom tag on the pins fairly easily trying to hold them from spinning. Try putting some Penetrene, CRC, or equivalent on the threads and nuts the day before, as well as half an hour before you start
Important ( ONE for no ABS and TWO if you have ABS ), undo the brake line bolt that holds the brake distribution tee block to the diff ( at the bottom of the flexible rubber brake line to the diff ), and also release the closest clips that hold the brake line to the diff, and make sure that the block is unclipped from the tag that holds it so it can move freely - I normally push it up, bending the solid lines a little , so I know it is clear and it wont catch. ( Place bolt in a secure location, as it will get reused )
You are now ready to start the actual spring changeover. Have all your jacks handy, as well as your safety stands, and for additional safety, I would advise having a second person around.
Remove the appropriate wheel rim, but only remove when needed, to keep it all as safe as possible if the car moves on the jacks.
It is a good idea to have a jimmy bar handy, but I learnt the second time that the rear springs pop out real easy and you don't need to lever them out - replace them with the new longer springs as soon as you can after removing the old ones for safety reasons, and remember that the old springs will be shorter than the new ones, so you will need to jack it up a little higher to get the new springs in. Even though you are jacking up the whole of one end of the car at the time, I advise working on one side at a time, so that if the worst happened, it would only be one corner that will drop.
I also learnt that I could place a jack between the diff and the chassis ( with an appropriate block to sit it on ) on the corner I was working on to jack the diff downwards which helped to make it heaps easier to remove the front springs, and it made it so I didn't have to have the vehicle 3 foot off the ground too.
The longer springs go on the drivers side.
Install the new gear, and don't forget to reinstall the brake tee blocks and bolts, and reconnect the diff breathers too .... :)
I hope that this gives you a few pointers.
Mic
