The
solar charge regulator main task is to charge the battery and to protect it from deep discharging. Deep discharging could also damage the battery. Solar regulators also help to improve charge quality. It is generally recommended to use charge controllers with solar panels with the rated output of 5W or more. Furthermore, you can also bypass the battery and directly connect your appliances to the solar panel regulator In order to run them. Solar regulators are maintenance free. All you need to do is regularly check the connections, ensure normal air flow to the device, and avoid placing it in direct sunlight.
