Just saw this double butane cooker for 60 bux on catchoftheday and ordered one seeing how I missed out on that other one similar to this, bugga, forgot the name of da udder one:clownredpuff:
I just upgraded to a gas (LPG) double burner. $50 from BCF, but you do need to buy a gas bottle too, I already had a 2kg bottle. I found those butane ones chew through the canisters way too fast.
Rays Outdoors now sell them for $34.95 but they don't come in a blow mould case (which is huge) normal price is $50 rrp. BCF will have the same thing.
I have the COTD one for about 18 months and its great but Rays have it all sorted now. The Blowmould case is massive!
I know that plenty of folks have used those butane stoves for ages without problem.......... But........ During our travels around Oz I heard of several first hand instances where folks had been using them & they blew up, luckily with only minor injuries, singed hair & the like. One person had their vehicle saved by a quick thinking neighbours with a fire extinguisher. The main problem is that folk tend to put to large pots or frypans onto them, which partially sit over the top of the canister compartment.
However I removed the one I had fitted to an external drop down door on the side of our bus after the seal between the canister & the stove became leaky. First I knew was when I lit the stove the flames weren't where they were supposed to be. I reckon I was pretty lucky it wasn't worse.
I had a heap of (brand name) canisters left over, & more recently bought a blowtorch attachment for them to solder up some Andersen plugs. New canister worked just fine for the first few I did, but then started leaking. I could see the vapour escaping. If I hadn't been on the ball it could have been pretty nasty.
As a result I've now given up on any appliances which use those canisters, I just don't trust them any more. When using yours please don't get complacent with them. Check EVERY time you use them to ensure you have no leaks.
Cuppa
I have the original U-Bute twin burner with hot plate and have never had an issue, also don't put over-size pots etc on it either. The blow mold case is very large and does take up quite a bit of room but still worth using it :)
...some good info there.
'Spose one should always check and tighten the canister before use.
Also have TCOD ubute 2 burner....... Works just great and again yes the case is big but keeps it all secure
Don't stroke it, TAP it!!!!.....
Has anyone ever read operating intstructions I know I haven't
They are really only for the kettle or small frypan.
Bit of common sense really ,plus why buy the twin burner for $35 when you can buy
2 singles for $12 each
Because this one also comes with a hot plate which as you know is handy for bbq's
What you tapin at!!!!!????
I've always used these puppies when out hiking - would last me days and never failed.. plus fitted in the palm of your hand!
http://www.wildearth.com.au/buy/opti...urner/opt00000
great little back up for the 4x4!
@ Billy bit pricey just for a single burner.
Can see its great as a space saver though,
yeah very true re the price - but the quality of build, ease of use, and space saving meant that it was worth it when carrying a 40ltr back pack with all gear for 3-4 days out bush.. i ending up collecting all different brands of these to find out which worked best.. cost me a small fortune but i do love em.. just don't know where most of my gear is now..
You can get the cylinder cheap fro woolies
I bought a similar kit similar to BB's on special from Anconda that had the burner, mini gas lantern, twin pot's, non scratch gauze type cleaner and carry bag for $60 that stay in the troll all the time.
The burner and lantern also come in their own plastic protective box case as well. Run like a dream and are used regularly. The lantern uses a Citronella blend gas canister I found through BCF and is awesome when the bugs are out
