Signs of the bbq jets need replacing?
So as I do things last moment. My three burner camp bbq ain't working as it should and I need it this weekend.
Symptoms...
- put on one outside (right side) burner, fine
- put the left side burner on and almost straight away the flame will reduce on both burners and then the left side will almost go out.
I swapped the jets over and it does the same thing but to the right side. Plus both burners do reduce.
So this tells me its the jets. Yes? This is all running off a full 9kg bottle too.
Cheers.
Re: Signs of the bbq jets need replacing?
Quote:
Stropp
Check your gas reg, if they sit hooked up to a bottle for a long time the gas will clog it with sulphur, check this first.
X2, and check for kinked hoses
Owner of
Westy's Accessories
RE: Signs of the bbq jets need replacing?
Quick answer mark is charcoal can't go wrong i haven't used my 6 burner since I bought it
Sent from my RM-821_apac_australia_new_zealand_218 using Board Express
Lol I know bud but I'm saying is to buy urself a charcoal BBQ you'll have no dramas
Bloodyaussie
Well then Steve you could just give it to me then, I will give it a good home...ha ha!!!!!!
Sorry buddy a 6 burner in the backyard beats gnomes lmao
Have you checked the line between the jets and the connection before the hose?
My dad had the same problem and found out a spider was in their. Sounds silly but worth a go
Yep td the waterspout ain't big enough for the two of them lol
the ferret
Crap in the hose mate!!
Cheers, the ferret.
That won't be easy!
