Hi Guys.
I need some help. I replaced the fuel filter on my ZD30 and I have been unable to bleed it.
Any tips?
Regards Rodney
Hi Guys.
Any tips?
Regards Rodney
Have you removed outlet hose on filter housing and tried to prime with hand pump on filter housing or is yours different .
I've tried it with the outlet off, I've even tried it with the fuel filter loose
Do you have compressed air on hand ? could remove tank filler cap and force air in the tank - but you need to regulate the pressure and reduce considerably . remove hose from inlet side of filter to ensure flow if you consider this option ,
Rodney I have done my fuel a heap of times in the last 6 months trying to sort out a problem. Solved! You should be able to take off the pump side of the fuel filter and put a plastic cup under the outlet and use the hand primer pump. Prepared to pump as much as 200 times if you have too!! It can take a heap to pull up from the tank. Don't give up!
Fuel filter tight outlet off and ship loads of pumping should get it done.
Hard and fast mate will get it going initially. The other option is to put a facet pump inline so when you do a service you just hit the key let it pump.
When pumping and you put your finger over the outlet pipe how much pressure should you feel?
Mine feels like there is hardly any if any.
There won't be a lot until you get fuel up to it. How much fuel is in your tank? Do you have a compressor you could knock up a venturi and suck it through
I have a compressor how to I make a venturi?
It's like a "T" piece if you push compressed air through the straight part it moves over the orifice of the t piece and creates a vacuum
It's alive!!!!!!
Thanks for your help guys. I ended up pressurising the fuel tank.
Cheers Rodney
