1 Attachment(s)
Even more light again approx20%
FYI .
If you are very careful and remove the globe shield your lights will gain a further out-put improvement.
I did this as I personally thought they still leaved a bit to be desired.
You will get a gain of another 20 + % extra output.
Inserted a pair of long nose pliers and crushed the cover up to pull out hole without scratching reflector.
Bear with me , I did this over a yr ago, twist cover sideways to loosen screw, and remove screw and then crush up cover and discard .
There could be a legal requirement for the cover to be there but I've seen plenty of factory oem without the cover, so it's up to you.
Just use globes that have the tips painted/covered.
It's some old school rule about glare/intensity of lights blinding the oncoming traffic.
Personally, lights are well focused and not blinding at night, I work nights so they get plenty of use and recon they are safe to use.
cheers
