Anyone found a kit to get the redundant rear lights working ?
My next project is calling.
http://www.ebay.com.au/itm/Nissan-GU...item5891570ed8
try these if you want to look ur self put gu patrol lights into the ebay search bar
Just found and purchased these Nissan GU 4 04-10 Patrol New TailLights FULL Functions! from www.carsrus.com.au.
$155 for a pair and wiring harness.
Hopefully they do the job. will feedback when i recieve them
Hi Paul, I have same tailights from ebay , yes there are ready to go for fitting ,passager side just plugs in , but driver side on my Ti 98 I had to do some wiring as there nothing there to connect , which was ok as there a rubber gomit just below the inside of rear cabin that you can feed the stop/tail and blinker wires from the bumper lights harness, hope this helps . cheers Alex p.s. lens unit do have big slot globes ,the same sharp as dash light globe , hmmm
The wiring harness they are talking about would be the wiring shown on the back of the light. I doubt it would be the actuall harness itself which is needed for the earlier trolls. I'm looking at doing the same as it's got me beat why they go to the trouble of making a car with dummy lights in it... But I am thinking of stopping past the wrecker and getting the actual rear harness assemblie of a later model car so its all done properly. I really just CBF'ed making one up. ;)
Thanks guys - Has anyone done this on 09 GU - as i haven't checked if the original harness plug is still there, I would think it should be just haven't checked yet.
As musdski said i might also see if a late model nissan has the same connector then i could just modify to fit a patrol.
I need to look at something similar but would need an aftermarket "Y" frame wiring harness made up to plug into OEM wiring so that the tail lights and the bottom set on my kaymar bar together
You will probably find OD that the factory wiring harness is in place in the guard and all you have to do is pop out the blank lens and you will nearly be a plug and play. The only problem light will be the reverse light as it only works on the Passenger side (go figure!) so you will have to run a single wire over to add the right side to the circuit.
Pretty basic mate. I didi mine on the side of the Murray River while camping ;) nice way to spend an afternoon ;)
Ah cool, I take it the lights in the kaymar bar would be run seperately then? Would be good for plug and play then :)
Hi, first I must say that you got a nice spec Patrol. In Sweden we are limited to the 3.0L Diesel.
I'm lookig for original tail lights made for other markets. I have found 26550VD325 and 2655VD325.
Is there anyone that got success in this case?
Please let me know when you get the aftermarket Y-frame wiring harness. My local Nissan dealer couldn't help me with loose connectors and pins.
Anyone that know where to get the connectors with pins? They look a bit like Deutch connectors but they are of another brand.
/Cheers!
im just going to drill mine out and whack in some led's seems to be the cheeper option and i dont see the point replaceing the whole unit if its not broken
have thought about that as well but decided against it and will use the original ones as spares for the "just in case" scenarios
By law I think you can only have three brake lights, two on the bar and one in the window, plus the 160 degree view of those lights.
So a pissed of copper could book you for this.
In saying this can't wait to get mine done.
P.S. great thread and responses (5stars)
Righto
Have connected the rear lights i purchased from http://www.carsrus.com.au/ off e-bay.
There is no loom plug om my 2008 GU. Ran the wiring from the trailer plug up through the grommet sitting above the spare fuel tank along the back from left to right.
The only loom plug that is there is for the existing left reverse light. That needs to be run from left to right in order to get both working.
They work perfectly. Am really happy with the outcome!!
paul
Got a link to the exact ones you bought? I have seen a few different types floating around...
Mudski
Here is a link to the exact ones i purchased.
http://www.carsrus.com.au/catalogsea...-21043LHRH-COM
Thanks. Whats the reverse lights like in them? Nice and bright?
Purchase GU 98/01 rear tailight set fully operational on Ebay from autopartsmate for $122.50 free post. Fitted perfectly into passenger side all functioning. Drivers side had stop light and right blinker connected but no earth, tail light and reverse. Too hard trying to source connections to bumper loom so with a peice of yellow tongue ran three cables under carpet and connected appropriate wiring from passenger to drivers side. All works and looks great and easier than stuffing around fitting globe holders plus all lights are defined and it took about hour and half to install.
The Baz
Lights nice and bright. Really happy with outcome!
You don't happen to have a pic of it? Im stuck between those and these.
http://www.ebay.com.au/itm/380395523...84.m1423.l2649
Not quite so.
If they are connected they must in pairs and must both be working but the main reason they are not connected and the lights are in the bumper instead, is because they don't conform to the Australian Design Rules of lighting angle visibility, because the spare wheel location blocks it's view from the LHS.
GQ's from 1991 on had dummy lights too and lights put in the bumper for the same reason because 1991 was when the ADR's for lighting and other things was reformed. If you see a GQ with no lights in the bumper it's a 99% chance it's pre 1991.
So you can have 4 tail and brake lights but even though you get these all working the dummy lights are still technically illegal if used because of the ADR's and a cop who knows the regs could ping ya if he wanted.
Cheers, Dave
I had HOLDEN globe holders fitted, however, the brake fuse then melted the plastic on the fues holder around the fuse, causing it to become useless, had to rewire the fuse arrangement with bakelight fuse holder. Worked OK after that.
I'm about to start this project. Looking at a similar kit of eBay, and have a late model GU so hoping it's as straightforward as folks are saying here.
Only query I have (for now) is do I need a different fuse, and what rating do people suggest?
Anyone looking for a cheap option, rather than buying the $150+ kit, you can do it for about $10
Go to Supercheap Auto and buy a globe holder and some new globes. If the new globe holder is the same as the one as your current reverse light holder (mine was, they might be universal), use the existing hole for the current reverse light to draw up a little template, then transfer that template to the dummy brake light and cut out a hole in the plastic to suit the new globe holder.
Then just piggy back some wires from your brake lights in the bumper bar and up to the new lights. Easy, cheap, effective.
