Difficulty shifting gears
I'm having a few issues changing gears in my '91 gq Td42.
It shifts fine when cold, after about half an hour or so of driving it becomes very hard to change gears (this problem comes and goes) with the engine of I can change no problem.
It does not grind except trying to get into reverse.
Double clutching does not help, nor does pumping the clutch pedal.
The clutch is not slipping, however I think it may not be releasing properly, not sure how this could be affected by different temperatures though.
Could this be caused by air in the clutch lines?
I have changed the gearbox oil, the problem is the same.
So i'm thinking the problem could be
-I'm in need of a clutch bleed.
-Clutch fingers worn.
-synchro problems.
-or a buggered gearbox?
Re: Difficulty shifting gears
Well not really.. poped the bonnet to check for leaks from the cylinder.. couldn't see any. Popped the lid of the fluid tank aaannnnndddddd...
No fluid... :o
So ill top it up, and look for leaks..
What is the preferred clutch fluid for Nissan?
Owner of
Westy's Accessories
Ok, dot 4..
Will I have to bleed it now? Or are they self bleeding?
Owner of
Westy's Accessories
