Can upload it via the pc as an attatchment file.
You still home or back away again?
TD, that is an angry looking tool
yeah compact I worked on the lines of a mini machete but with a thicker blade.
Once I drill holes you can put a stick/branch and use as a mattock or pic , then
get a longer branch and lash it on to make a spear, sort of lol
http://www.ebay.com.au/itm/Cold-Stee...item46147b01c8
Those cold steel knives are good, never been sure on the hollow handle though
Attachment 42856Attachment 42857
Ok, my design is a little like 3D's, in that it is a heavier blade based on a gollock/mattock. The blade is thick enough to stike with a hammer (to help splitting wood). The spine has a section of woodsaw, which I wanted to slightly bow, giving it more bite. The blade is Tanto shaped (just because!) and I have tried to make the blade tip usable as a screwdriver tip and a guthook at the tang handle end. The blade is approx 3in wide and 10in long and 5-6mm thick. (did I mention that this is gonna be heavy?) I will drill holes along the blade so that the blade can be attached to a pole or stick.
The handle is going to be hollow, with the end cap double-threaded, with the end cap one side and a spear point the other. Other small items will be able to be stored in the handle.
Still up at site so can't make this just yet but looking forward to giving it a crack.
Hi all Blade-discounts are only charging $10 post to OZ, so I'm getting a
few Timber Rattler bone handled Bowie and the Bud-K behemoth bowie
http://www.ebay.com.au/itm/Timber-Ra...item1c3daca047
Also got my eye on a Colt star pommel stag handle bowie OA 20.5in a beast
That is a great looking combo, will definetly look at getting a set
Cant knock back $10 postage from the States eh
Check out the hunters den on facebook, they have a new milspec folder that doubles as a fixed blade, 2 molle sheaths included, awesome bit of kit
here's the stag handle Colt Alamo bowie, yep its a horse
http://www.ebay.com.au/itm/310923984...84.m1423.l2649
Blade - discount post went back up to $25 bummer
Here is a pic of that knife i mentioned
Attachment 43091
Attachment 43092
