The car likes the high country..
Central locking is working again.. Lol
Give it time the rest might come good..
Drove it to its new home
Oh that's good mate I thought you meant new home as in sold it!
Used it Attachment 43799Attachment 43800
Also used it.
My sub tank light stated on the dash after a fuse was blown.
Even after replacing fuse sub tank would not work.
So after surfing the forum for some info, it was suggested to remove the fuse and disconnect battery for an hour.
Did this and re-assembled it all, with total success. Light went off and a working sub tank again.
Open the fuel cap to hear trickling fuel again. Happy days. Thx NP forum. AGAIN.
Traced back, found and fixed my grounding issue. Installed some LED strip lighting across the back of the boot and wired into my little electrical panel.
Also pulled all the seats and floor up to give it a good clean which it desperately needed. Found a few pens and keys along with 20c in change under the front arm rest.
Let the rain clean it...
Little peak, front to back scrub bars sliders rear bar rear quarter chop.
http://www.nissanpatrol.com.au/forum.../2014/05/1.jpg
Put some rubber flares on. Its a fat Q now
@ Heals check the 4" flares for GQ's on the other thread
Upgraded the interior lights to LED's and fitted the Kaymar shovel/hi lift jack holder. Bit disappointed with that one, the hole for the shovel handle isn't very big. Anyone else found that?
Converted the rear lights to led. I've done the Xmas tree conversion and all lights are now led.. Looks great.. Just need to get the front parkers done with dual brightness t20 and I'm done.
Attachment 44145Attachment 44144
Added some LEDs to my rear door table
Hit limp mode for the first time ever! 19psi in third gear..
Nope no need for resistors just replace the standard ones with led style ones and away you go. This is the ones I got obviously they are 24v because I have a safari but you can get 12v ones too
http://www.ebay.com.au/itm/221423169...84.m1423.l2649
While I had the ceiling down I decided to relocate the Redarc BMS head unit to the overhead console. Routed the head unit cable up the B Pillar and across the roof.
http://i935.photobucket.com/albums/a...psybjr4q6x.jpg
http://i935.photobucket.com/albums/a...psngsejhav.jpg
http://i935.photobucket.com/albums/a...ps1so03mma.jpg
Tracing the feared 24v to 12v converter wires! :O they are all cut....
Replaced the front 31-10.5x15 tyres
