Couple of shots. The angle for the installed plate is terrible, plus there is too much reflected light from under the car so the flash won't fire. I will have a crack later tonight in total darkness for the installed plate. I am yet to actually fit the pump as i have a small relocation of the starter motor cable to make so a hole is there, but it will work. The hose itself will simply be a 'whatever is avail, but looks in the order of 450mm inside dia' at a guess. The pump pulley is 50mm, the driver is 125mm, so nice step up at idle, plus when I get my hand throttle assy back from BD I can bounce the base revs up also. I intend tig welding an identical 125mm pulley onto the existing PS pulley - waiting for this to arrive from BD now. The outer pulley will have the centre removed.b Its a simple system that I used on my 2.8 for 10 yrs and its simple. Probably takes about 3 mins to adjust once you get the belt ready.
Attachment 69802Attachment 69803Attachment 69804
I don't know if your engine is the same format - mine is Optimiser N/A, but the two bolts I am using are the ones that hold on the power steering bracket, 10mm or there abouts. I might end up installing slightly longer bolts as the bracket plate is 6mm and with the nut, there is only room for locktight - might get a nyloc on with uck, but no spring washer.
You can see the bracket is a total oddball. If you think its of value I can trace it out for you and post - I don't think a dimensioned drawing is going to be feasible as its 'cut to fit' and all using 'backyard garage tools', so would be nicer with a mill or laser cut. PM me with an address and i can do this over the weekend.
