westy those links dont go to the items????
We'll guys. It's in..
And the rebuild has begun..
10m2 is enough to do the whole.. And the fire wall twice.
Started reassembling the dash.
Have 5 sheets of butyl left so I think I'll do the inner door skins to.. Why the hell not hay..
Can't wait to Start it..
Attachment 37586
Attachment 37587
Did you use that special roller to apply the sheets ,BTW bloody big job there buddy. lol
Sure she'll be happy with the results,,
did you slide some pink batts in the 1/4 panel cavity?
WwwWell I picked up this stuff
Attachment 37764
And shoit Its thick..
$45 ish from auto barn.
As I suspected its basically paint on rubber / tar, but I don't mind as iT's going in the rear 1/4's, wheel arches and the few spots I had to weld repair to give those areas the original coating..
Well, shoit it's thick.. Buy throw away brushes.. And some rubber gloves..
You get a lot of coverage from 4L.. I'd say easy a few coats of the whole floor pan (but keep reading), after applying a good coat in the 1/4 (slapping it in) I used roughly 150ml..
This stuff is good for sealing a surface, but in my opinion has nothing On the dynamat..
After 1 good coat there is no difference between coated and uncoated panels, where with 25% coverage of the panel with dynamat it had a huge affect.
So imo and as I suspected its no good for "sound dampening" as it has no weight to it (refer to link in first post), but
Sealing, rust prevention and mess making.. Yes it ticks those boxes.
But in another side note, 4.5m2 of dynamat has covered the car. I didn't do the cargo area Floor as the draws add a huge dampening affect, But I have enough left over to cover the inner skins of the front doors. So if you want to do the cargo area it's perfect.
I went with more a 75-80% coverage with the dynamat. If you stretch it to 25% then the 3.5m2 pack will do..
Are you painting the inside of wheel arches with this "stuff"?
Yep.. But shoit it's sticky..
