I GOT IT!!! now just gotta fit it. and the engine chassis mounts arrived for my GUIV. nearly ready to bolt it in. . . .
great read and pics, you certainly seem to love the patrol's.
Intercooler fitted. I bought SFS silicone joiners thismorning, not cheap stuff, last time they cost me $14 an inch!!! this time i ebay'd em. . . . .
1x 100mm long straight hose 102mm ID.
1x 500mm long straight hose 76mm ID.
1x 90 degree reducing bend 102mm-89mm ID.
1x 90 degree reducing bend 76mm-51mm ID.
1x 90 degree bend 102mm ID.
Im running 3inch intercooler pipes all the way. im buying the stainless bends and cutting into shape, and the fella that made my snorkel is welding them, it will look better if he does it:harhar:.
So pulled bullbar back off,
iv flipped the power steering cooler, mounted it behind Intercooler. and just run flexy pipe to the pump i got from enzed
i got new brackets made up to mount cooler a few mm further forward and higher. cooler is now in its final position.
all AC lines cleared perfectly, its bang in the middle, as high as possible and a good depth forward/back.
Next step is to cut the bullbar brackets some more thisavo to get it to clear the 3in cooler pipework. then ill start chopping holes to run the pipes through the Rad support panels.
Iv already taken the PS pipes outta the way and horns etc, shouldnt be to hard.
What you reckon? cut the entire wings off or just cut holes?
Wings off i rekon
If it was mine i would cut holes,a pain in the butt,seems like you have it sorted
are you sure your far enough forward for any debris to clear or be cleared
between the rad and cooler,i know you like mud is this going to be a problem with the cooler
PS cooler now mounted behind Intercooler. and set in its final position. very close to winch. very close to air-con line on drivers side. good height. should have maximum airflow.:biggrin:
