Lovely! How does that stuff feel compared to car builders acoustic liner?
Sweet, happy days. The dynamat I used did a good job at giving the car a solid feel and stop vibrations, but I think it was the foam that made the biggest sound deadening. Vast improvement!
That's what I was thinking to. So yea I'll be laying strips of the butyl Mat threw the car and then smothering with the foam..
Can't wait..
Fitted the new bottle and motors, took ages to clean all the crap out of the pipes........ But man am I happy, after 3 years, I sat in the car and just played with the washers, front and rear and have had to fill up the bottle twice, sad I know but I'm sure the novelty will wear off eventually
Reading all this about what you guys have to do to your GQ's makes me appreciate having a GU that does not require all that work.
My car is already quiet to drive in and the wiper washers work too.
Been a bit slow posting. Recently fitted C/O injectors, new glow plugs & adjusted tappets & timing ( Denco Wagga ) . Fitted 2" lift - Lovells coils, EFS Leaves & shocks , greaseable shackles , replaced all bushes & coil insulators ( Wodonga Spring Works ). Fitted EGR blanking plate, flushed intercooler out & removed butterfly ( Old Wal ). Took a quick test run to Innaminka via Mungo, Menindee, Tibooburra, Cameron Corner etc (3300 km in 7 days). All went well. Averaged 14.8Ltrs / 100 km with slide on camper fitted.
Fitted up an ARB compressor today , space under the bonnet getting tight but with a little messing around got it tucked in nice next to the master cylinder Attachment 37251Attachment 37252
Diffs , gearbox , transfer oils , ready for straddie , boat trailer bearings x 4 , and camper bearings as well ,
Well we're done. Body lights fitted.
Attachment 37280
Attachment 37281
Attachment 37282
Tail lights
Attachment 37283
And I'll get some more when all done..
And I couldn't bring myself to 1/4 chop.
There still in good knick so I don't need the extra work atm..
Will make some bumper wings to suit the panels..
Looks good westy I gotta do that soon to my 1/4 are getting bad dont want the rust to spread to much.
I broke mine today :( for some reason my rev and temp on dash has stopped working everything else is fine and I just cant think why :(
That's looking great Kallen
GQ - More truck than car and nothing wrong with that!!
're installed the front shocks. It's actually drivable now. Lol
Cut out the rust and treated the area, weld in a piece tomorrow, then retreat it and paint it.
Then sound deadening... Yay..
haven't installed it yet but picked up my long range sub tank to be fitted for the simpson trip, also a couple of 100 amp isolators for the wiring and a 1500watt inverter for the cappuccino machine, gettin sorted slowly.
Love it! A cappuccino machine in the middle of the Simpson. Who'd have thought that was going to be the norm soon.
We took one of those little Nespresso pod machines on our last trip up the Cape. Was bloody nice to wake up to. It wrung the neck out of the 2Kva Honda though, but worked a treat.
I use a percolator, same as at home.
I got lazy though and more often just put the coffee ground in the cup. It just settles on the ground. I don't like instant "coffee".
I'm getting there...
Attachment 37529
Went for a drive with no set plan , ended up on the beach for lunch , life is toughAttachment 37530
I also picked up a couple of tai lights free from that other forum, I will drill them and fit up the light conversion in them.
I let my GU sleep in this morning......no work today"......yahooooooooo
put the new head on
Attachment 37569
adjusted the tappets..put the inlet manifold extractors and plenim on..new water pump...starting to become a motor again....now too remembe
Got the car back from the panel shop after having the flares painted and a good polish, now for the new bullbar Thursday that will change the look a bit;)
