Yep ☺, Anthony . . .
New boots with steelies
Sent from my XT1068 using Tapatalk
Besides my friends your the only one that calls me Johno.
Here you go TD just like the other thread.
http://www.nissanpatrol.com.au/forum...2016/07/63.jpg
http://www.nissanpatrol.com.au/forum...2016/07/64.jpg
Looks great! Johno! :harhar:
http://www.nissanpatrol.com.au/forum...2016/07/65.jpg
Fatz Air box and a Radius Snorkel. Then a 4inch intake for the 3071 soon. The one Ben gave me is a no good.
Mine didn't have the anti surge. To be honest I don't even know what or how the anti surge will affect my setup, plus I dont really want to go changing this as it drives fine now, its just sucking air through a straw though right now. The wheel size is larger to suit the housing Ben gave me. Only by 1mm but, knowing my luck, I will just root something if I change too much. Getting housing with the everything the same, just the intake diameter different seems easier.
Bene also said to me a week or so after the meet down here, he wasn't confident that this housing will work on my turbo too. But it might. I asked MTQ, gave them all the specs on mine and even they didn't really want to say yes.
I'm at your peril Matty. Whats your thoughts with this housing? I haven't ordered this part yet. I don't know anywhere near enough to go buggerising around changing turbo bits mate.
I just thought to simply change over the housing to the larger intake and thats it.
Hey Mat. Do you know the Cat part number for the battery that fits under the bonnet of the GU? My battery is stuffed, I rang CAT and the guy I spoke to was piss farting around with batteries not even close to what would fit. Looking at their website and no wonder, its one page per battery so it takes for ever to look though their range.
Anti- surge wont effect anything. A/r wont effect is operation but will allow a little more volume for a given psi. If the wheel is 1mm smaller then it wont work. Clearance has to be less than 0.010".
Just run 4" all the way from airbox to turbo and just use a short 3-4" silicon joiner at the turbo.
5 gu 17" rims, one brand new with a brand new 285/75 cooper on it and a good set of bfg's.
$500..
Cant complain..
Na I've had a helper jump in..
Big thanks to @MB..
Champion
2x shocks https://www.superiorengineering.com....oduct_id=26452
And sway bar disconnects https://www.superiorengineering.com....filter=140,355
Yea they do sell the rubber covers seperate not sure if they come with them I didn't ask.
The armada extreme on the rear came with but pic didn't show the covers
In all honesty I think the shocks in the patrol are quite well protected..
They are behind the axles, springs and everything else on both front and rear..
You only have to check out an old shock to see the pitting and sandblasting that occurs. Obviously its different depending on the type of terrain you're on. Heaps of gravel roads at speed would certainly mean stone chips. I reckon for the relatively cheap price of the boots, compared to the shocks, they would be a good bit of protection.
>>>tappin from tassie
I went and saw @Lights today..... Might have bought a new Light Bar for the GQ! and a couple of other lights too. Paul has some very very kool lights. the New LED Light bar is a brand new product and measured 500% brighter than the Aurora Lights of the same size on Pauls LUX meter. Looking forward to mounting them up. If the bar fits i will buy one for the GUIV too i think.
Thanks Paul always a pleasure mate.
No they're not. The shafts themselves are as robust asthey can be. But they are still either chromed or micro polished. Finer dust particles will easily damage the shaft surface, they arn't that well protected at all up front.... I know because the shaft boots I asked for with my kings that never showed up would have stopped the pitting on one of my front shocks. But I bent that shock so I dont care that much anymore
Fiskars splitter axe. Hope its good
