I just used my trolly jack with length of 100mm square timber on it to lift the body.
The front seats need to also come out as one of the bolts screws in the opposite way to all others. Dont know why...
And there is a small crossmember just infront of the rear fuel tank that is bolted to the floor. This needs to be undone too otherwise the rear mounted will be impossible to change over.
Took me a few hours to do.
Id recommend replacing the front mount bolts only too. These bolts will be rusted in for sure as they screw into the radiator support panel. All the other bolts will be like new still.
Cost is not a lot for what you get too.its about $350 from memory for the set or bushes.
