I hope your joking....
Just put the money down on a new set of rubbers and rims. Km2's on steelies.
I bought a wiring loom, new washer bottle and washer motors, and series 1 lights so people stop almost running up my back end when they tail gate me.
50A solid state relay
90-110 psi cut off switch
50 degree thermostat switch.
Small barn door extension bracket..
Next is a compressor switch and led light bar switch.
Bought a "winch in / winch out" carling style switch for "in-cabin" winch control. Not going to wire it up the traditional way. Going to wire it to a warn winch plug and only plug it in when required.
Bazza
Got it today, had an old battery to try and recharge so hooked it up with the blanket flat on the drive at 2.00 pm saw 6 amps on my clip meter.
The high voltage light was on which means the battery if already fully charged, that is not the case. It also doesn't work at all on the Redarc BCDC solar input either.
Give it good test over the weekend and compare it to the folding 120watt panel I have.
These meters show Amps I think, no idea how accurate though
I have a few with 50amp anderson plugs on each end
http://www.ebay.com.au/itm/Digital-L...kAAOSwnDZT~DG1
Yeah I have a couple of Fluke Clampmeters, hard to go past if you have the cash
It's not the meter itself, it's the method.
For the induction pick up to be accurate the conductor has to be centred and parallel.
That's why industrial hall effect transducers in fixed plant applications are usually sized to be snug on the cable.
Doesn't matter all that much tho, you get a 'feel' for the gear after a while.
Mmm yea about that, I was hoping they were joking. I was looking at 285 70 17 and they were 420ea
410 is fine mate.
Micky Thompson 285/75R16 MTX P3, walked into local ARB store to order as he quoted $400 each a couple of days ago, list was $420??, said they just emailed a flyer $376 each now. Saved 2 pineapples you beauty.
Brought a grab kit of muti coloured heat shrink,
makes any electrical job look neater.
http://www.ebay.com.au/itm/328Pcs-8-...IAAOSwFnFV98JX
Also brought a grab kit of various size split pins,and
some coloured cable ties 100mm long 6 colours
4 of these babies 265/70R17 @$300ea. went from 275 to 265, lets see what diff in fuel economy it makes... probably none.
oh and bloke reckons I'll be getting close to 120k out of them... let see.
Attachment 65435
Two bottles of wine and a slab of beer for the weekends activities. Nom nom.
A pair of Maxtrax from Supercheap Auto for $268 on special at the moment.
25% off rhino roof bars..
$250 for a complete 225kg twin bar setup with aero bars..
Don't mind if I do..
Happy birthday to me....
and a light bar will mount underneath lol
Yeah for sure the price is right, thats for sure.
Just not a fan of the flood on the sides but Id put
up with it at the prices they go for these days.
My 240 watt number is all spot beam and it has awesome side ways
illumination, these come in handy too, or whip up some of your own
http://www.ebay.com.au/itm/171274323...%3AMEBIDX%3AIT
I don't see the point of a flood / spread led bars.. spot is like 30 ish degrees already.
But there on. .
http://www.nissanpatrol.com.au/forum...016/03/182.jpg
http://www.nissanpatrol.com.au/forum...016/03/183.jpg
Karcher under body cleaner, on clearance at Bunnings.
Graham
Did you use that 6mm plastic packer, plus go around and make sure they're all tight.
Ive only seen one white patrol with the door tops painted black, looks awesome, you'd
never pick it it just looks different,
Back to racks did you fit the rubber strip into the top?
AC air filter kit arrived today from NIZZBITS.
Pleasantly surprised with the included clip.
Not a bad price at all mate, is that the Vortex RL10's?........... are you sure that rating is correct though, according to Rhino's website the rating was 100KG, for a 2 bar system and 120Kg for the 3 & 4 bars.
Looking to swap over to these in the near future from my heavy duty ones
