On Mine, the bolt is slightly to the rear. Can't see exactly as there is a big washer in the way, but I can see about 2mm gap at the front of the washer. If that makes sense. If u want I could pull the bolt out and take some pics for you.
Its ok now Im making a plate the same shape but 6mm in from all sides with a 12mm x 16mm slotted hole .
That should allow it to fit all and cover that hole. oh and 4mm thick should do it I reckon
That sounds like a win to me.
Bloody hell mate, these things have turned into a pain for you
Just a quick thank you to all for the support through the year,
have a great Xmas and New Year and stay safe.
Look forward to all the stories next year, again thanks
John [TD]
Hi all need some help from the GQ owners out there.
Im getting some switch plates made for my GU that
suits the panel on the centre console with a few knock outs for some
switches, as we all know they are way too small.
I have the GU one all drawn up and will house 3 x Carling switches
and one toggle switch of your choice. The size of the GU one is 230 x 30.
All I need to know is the size of the GQ one If its the same great if not
a seperate plate will need t be cut. speaking of cutting it will be cut
from 2mm black perspex.
I've got my centre console out of the car at the moment John... let me know exactly what you want measured and I'll have a look at it tonight.
That space where you normally put the lockers switches
Just measure from the front please trying to make it as
easy as possible for others
Bumped for Winnie or other GQ owners
