First off the auto specialist test drove it and said the TC is stuffed, and it was so we replaced that, then he test drove again and thought it didn't feel right so had a closer look and found the tps was missing, then found it was missing because it had a carby off a manual in it so no place fir the tps. At that stage the error code was showing "problem with the tps circuit". Got another carby, fitted it with a new tps and the code went away but problem still there. Pulled box out to thoroughly check the internals, box was in awesome condition, auto specialist said it looked like it had dine less than 5000ks since a reco. Decided to fit a nomad valvebody while it was out. Put all back together, still had the problem but showing no error code. Tested temp sensor and found it was faulty. Put a second hand one in and the problem was gone completely (also no codes showing). 6 weeks later the problem came back and now showing that error code........ So I thought well maybe the second hand temp sensor had failed so I got a brand new Nissan genuine one fitted and still got problem.......
tappin it
