Took second battery out and front head lamp out..
Had the headlamp out to remove that stupid duct work anyway. .
Also put a fair wacky of it inside to so it's sealed from both sides..
So what's happened..
Compressor is hard mounted in the rear 1/4.
Hose sits nicely in the window pocket..
I have also made a vertical pantry for trips with no van..
Awning has LED's and a small strip along the roof..
I also moved the side wing of the draw system back 30mm to fit switches etc in without fouling the door..
Also due to the bloody blow moulded table not fitting between door and barrier I had to make a quick table top which sits in the draw quite nicely..
Not quite as big as I wanted but it's all the laminate I had left..
And 3" exhaust is in and awesome..
Light bar is on, and winch is finished..
Finally..... untill I get a in / out switch.....
http://www.nissanpatrol.com.au/forum...016/05/410.jpg
http://www.nissanpatrol.com.au/forum...016/05/411.jpg
http://www.nissanpatrol.com.au/forum...016/05/412.jpg
http://www.nissanpatrol.com.au/forum...016/05/413.jpg
http://www.nissanpatrol.com.au/forum...016/05/414.jpg
http://www.nissanpatrol.com.au/forum...016/05/415.jpg
http://www.nissanpatrol.com.au/forum...016/05/416.jpg
http://www.nissanpatrol.com.au/forum...016/05/417.jpg
http://www.nissanpatrol.com.au/forum...016/05/418.jpg
http://www.nissanpatrol.com.au/forum...016/05/419.jpg
Holy cow Kallen you have been busy no wonder you haven't have time to make a rear light bracket lol
Don't worry I'll just have to go down and look @Stropp s
Looking awesome mate
traitor......
Ok pillar pod is in with an egt boost and oil pressure gauge..
http://www.nissanpatrol.com.au/forum...016/06/242.jpg
Nice work Westy. Those gauges look bright! How are they when night driving?
Is your pantry box completely removable for those times when set up in camp?
