Well it is a most there few more tweaks slowly slowly.
still think there is something else but will get this right first
That sounds like it could be the issue.
So winding the dawes in will reduce boost?
OK if I can I guess that would be a bad thing?
so blew in valve and can blow through it.
If you can, the boost won't rise, any boost pressure will just pass through the ball in the dawes. Wind it in atleast half way and then wind the needle valve in also, right in. (To shut the vacuum supply right off) Then start the car up, and unwind(open the vacuum supply) the needle valve until the rod drops. If it doesn't drop, I would think it's either incorrect plumbing or the actuator is stuffed. Think.
Attachment 56542
So this is the set up I think it shows all the parts in the set up.
I can only get 5 psi out of it at the moment.
I put a new spring in today (thanks for the fast shipping Mudski)
I will keep fighting the gremlin just posting an update.
O.k First thing I notice is the dawes is almost upside down, sort of, lol. I may not affect anything but its best to have the dawes sitting vertically. It just eliminates the possibility of the ball not seating itself right. Next is the clear plastic hose and the Y piece you have, those plastic pieces are prone to crack and leak. The plastic hose I take it goes to a boost sensor or something?
Can you take a pic of the other side of the intake hose? The needle valve is hiding the plumbing behind there.
