I dont hate.... it is a such a strong word.
And no Eric no problem I welcome all the discussion as this is a topic that has many misunderstandings and so much to learn from others, its also the time of year to nut this sort of stuff out.
time to nut this stuff out was last winter before the temps rise, weather wise
While testing that piston slap seems to go away with oil pressure after start up. Because td42's are simple mechanical injected they don't compensate by adding more fuel with lower water temps to warm the motor up quicker. You can see how sensitive they are when you block the egr which is used to help atomise fuel with heat in that on the td you won't get a flat spot during warm up unlike a petrol motor
Never heard a diesel moan and windge before......
On the bench uts a bit different coz you will notice that a 82*c thermostat will start opening roughly at 65-70*c and fully open by 80-83*c. I'm going to go thru basic operation of the thermostat but as one side heats ups (usually the bottom) the spring softens and looses its tention To allow water to pass thru usually at a lower temp which will cool the spring and its tention close the thermostat till it equals all if the cooling system.
On my 4.5 the gauge will show NOT from 64*c-96*c and will creep up at a higher temp.
The zd has more electronics to run more efficiently alot like carby vs efi so it will be significantly affected by water temp coz of the coolant temp sensor adding and decreasing fuel with different temperatures
intresting read, currently looking into rad options for my tb42e turbo, not so much overheating but rad is of an unknown age (at least 7 years) and plan is to up the boost early this year so will need more capacity to keep it cool
Even with the "simple" td42 there are things that are in place for when it's cold. Things like glow plugs help when cold and more often than not they actually operate until a certain operating temperature is met. Temperature on a diesel does affect it, no doubt of that at all. Not to mention like any other engine design it is meant to operate at certain tolerances in a certain temperature range for least amount of wear and efficiency, this engineering side of applies both to petrol and Diesel engine design.
Sorry George but your a little out of your depth with the understanding of the diesel. Please just comment on what you know instead of guessing.
I'm not trying to discredit you as you do have quite a bit of knowledge.
Why would you say I'm guessing then??? Doesn't make sense??
You're right I don't know much about diesels but what I do know is we're talking radiators and cooling systems, yes it affects the lubrication system and the viscosity of oil but unlike petrol like I said before doesn't use water temp for the fuel system. Water does not flow thru the injector pump to heat tje fuel and the glow plugs heat the air inside the combustion chamber not the fuel or water. Gq td42s don't have an ecu so why do they have a coolant temp sensor?? That would be for the glow plug relay which is on a timer from what I have seen while testing and as far as I could see when that coolant temp sensor got to a certain resistance the glow plugs wont get power. Now correct me if I'm wrong but if a diesel was affected by water temp like a petrol it would have a ecu to control the fuel delivery to aid in not only performance but also in speeding up the time it takes to get to NOT ?? From what I can see the leter model stuff does, like a petrol you richen up the a/f mix to raise combustion temps, to heat the coolant faster, to get to NOT quicker, to run more efficiently to use less fuel not to mention lessen wear and tear.
So now after this little lovers tiff what have I guessed? ? I'm curious and would like to know ?? I don't like being wrong and if you knew me well you would know I wouldn't speak if I was
not wanting to "buy" into the above comments, but I am thinking (and am very likely wrong........ almost always am.........)
is there a different temp setting for the Petrol thermostat V's the Diesel one?
wouldn't the petrol one open quicker than the diesel one?
or
atleast regulate the water flow differently?
I'm curious.......
my TD42 is getting hot when towing my van........ so I am watching this for some insight to help me........
I just purchased thermostats for my petrol and diesel and they sold me the same one for both 4.2 engines. Haven't checked if they fit yet.
My TD42 just spent every hill from VIC to coffs sitting on 3/4 temp (bout where the fan kicks in)
And EGT's of 500/550 so I will be seriously looking into the 3 core rad next time , never got the car this hot in the Simpson and Kimberly .
I did remove and clean radiator before trip and it was covered with mud just from the 2 trips to matts so I don't see mud clogging a 3 core as any more of a problem
