This is what I just drew up quickly. Would this work ????
Attachment 47203
Attachment 47203
It will, however when you turn your work light switch "manual switch" on your reverse lights will come on
One rocker switch on/off/on or on/ on would stop that rather than 2 individual switches
Also, that Reverse switch is the switch at gearbox, it's not an additional switch. I didn't label it right. I'd have the relay at the back of the car, and the reverse wire I'd pickup from loom, on the right, just tap into it, so when it becomes "live" it triggers the relay.
I've modified your drawing, basically I've added a diode between the reverse switch and the relay, this will stop the reverse lights coming on with the manual switch:
Attachment 47204
You can buy them from Jaycar or eBay them (Cheap cheap):
http://www.jaycar.com.au/productView.asp?ID=ZR1004
OK. Done some wiring tonight. Bought the diodes as flex suggested. But I actually went down the path megatexture suggested. And below is the updated diagram, of how I've done it. The on/off/on switch replaces 2 switches, or a switch and a diode. Flicked up, is normal/usual position while I'm driving for reverse etc.... Flicked down, is when I want the light on without the reverses, camping/work light etc... And the middle turns them both off. I got all the bits, but haven't finished the wiring yet, on paper it should work, but will find out tomorrow when I put it in practice!
Attachment 47241
That won't work mate. Your diagram is wrong.
Your tail lights are different to the one pictured... :p
