I bought a Dawes valve today egr was already fitted, how do you guys tap into the boost hose the black metal one?
And where can I buy a needle valve in the Campbeltown area?
That wasn't aimed at me was it?
I'd really like to know what the limit is for these donks. I run mine at 20psi and just did an hour hour run towing a 1.4T trailer with thew boost at full prolly 60% of the trip. Ran like a dream apart from the hills where I could have gotten out and pushed. Lol
I did set it to 25psi just to see, still no limp mode and jesus! It really went but was to worried to leave it. Once my TD42 build is ready to drop in I might screw it up just to see what goes bang first as I won't be able to sell the engine for anything so I might aswell do some r & d with it.
TW, there is multiple ways mate. I used what is called a bulkhead fitting, do a google image search to see what it is. But I welded mine in for a better seal. Or you can use a purpose made weldable fitting, that I happen to sell lol, which is made for both pyro fittings and boost fittings.
Either way it good though. just weld it in though if you use the bulkhead fittings. They seal a lot better that way.
