You removed the birds nest from under your dash yet?
got the fridge drop slide fitted, now i can open the fridge without having to stand on a box.
@ Stropp are you going to cage in the fridge to make better use of the space.
No cheap but a great idea that's for sure
Ok, I didn't look much when I got home as it was dark and now I'm not near it BUT dad dropped in a piece of rubber he found in his drive after I visited. I know it's a long shot but does this look familiar to anyone? And also could that be the source of the clunks? It looks to me like it could be from the radius arms??
Ill put all this on another thread later to maybe help any others
EDIT: diameter is about 50mm
With the sub tank pump not working and a full sub tank, I decided to get a little fuel pump 2-3 litres per minute and empty out the sub tank.
Although I only got empty half the fuel tank.
The hose was quite difficult to feed down to the sub tank with so many twists and turns.
In the end I couldn't get down from the fuel cap so I opened the plastic guard from under the rear wheel arch and opened the fuel line and managed to get the hose all the way in from there.
Finally got the Catchcan in but I think the bonnet is just resting on it. Don't think I will bother moving though as not pushing it up. Stereo going in next month, thank god.
